Show Us Your Bryce Renders Part 11
Adding to Cart…
Thought I would play around not..making landscapes ...bit rough and simple I know but thought I'd share anyway
Tumbling Balls
spuddy - looks very nice, a bit like spheres in a cave.
Two identical terrains, one upside down on top of the other with different materials for the upper and lower terrain. Each lamp consists of three radials, two of them with different IES gobo to shape the beam, and an HDRI with only 60% shadow intensity to brighten the black shadows. This setup creates two different tunnels, the first has the camera to look into the left, the second into the right tunnel.
Spuddy - beautiful render, I agree, looks like one of those ancient caves.
Horo - the tunnel renders are awesome, interesting work
awesome renders guys!!! ....great work :)
Mermaid010, Horo, Rieke77, spuddy, santi010, Tim82: Thanks very much.
Spuddy: Nice abstract, with very nice texture in the background
Horo: Interesting way of creating good looking tunnels.
One advantage of an abstract is that a few changes, e.g. to the distorted lens and the sky, can give a totally different render. I also changed the human figure, for 'policy reasons'. I think, in the second render, I could have given her a different texture for the dress, but forgot about that.
In the first one, I turned the lens around 180 degrees. In the second one 90 degrees and made it linger in the (new) y direction.
Hansmar : three very cool renders, I like them all.
spuddy : agreed, looks like spheres in a cave.
Horo : Great spooky tunnels.
3 same canyon terrains based on downloaded height maps. The castle was also a free item.
Hansmar - awesome renders once again, the last one Lady Envy3 is my fav
Adbc - wow beautiful render, the material and lighting blend very nicely
mermaid and Tim82 - thank you.
Hansmar - thank you. Again very cool looking abstracts through your specual lens.
adbc - thank you. Great terraced landscape with the castle that blends perfectly into the surroundings.
Same as above but both tunnels as seen through a wide-angle fisheye lens, 150° horizontal and 100° vertical. A tiny bit of the terrains had to be removed in the TE and the camera re-positioned.
Horo - very nice effect with the fisheye lens
mermaid, Horo : thank you.
Horo : The effect with the fisheye lens is awesome.
mermaid and adbc - thank you.
The shapes are from the Hypertextures Base set and have a hypertexture material. Inside each one is a smaller copy with some reflection and transparency with a high refractive index. Lit by an HDRI that also comes with the Hypertextures set. The inside shapes create the dark shadows, the outer shapes the bright anti-shadow.
@ spuddy - your Tumbling Balls looking great!
@ Horo - wow, I like your tunnels. The third (fisheye) is my favorite.
The image with the shapes are awesome.
@ Hansmar - wonderful abstract renders!
@ adbc - beautiful image!
Horo..Mermaid010..Tim82..hansmar...adbc...rieke77... Thanky you all very much
Horo love all your posts the caves are great and the shapes are very sharp
hansmar love your alternative abstracts the last one is my favourite
adbc.. Lovely render nicely put together
still exploring things ... expressionism meets Bryce Ha ha
Horo - Wow beautiful effect, I like the reflections
Spuddy - a very nice paint-like render, so true expressionism meets Bryce, well done.
Rieke77 and mermaid - thank you
spuddy - thank you. You start to get the hang on Bryce. Very nicely done scene.
@ spuddy - your expressionism render looks beautiful
Horo : excellent render with the shapes.
Rieke77, spuddy : thank you.
spuddy : Expressionism is awesome.
Thank you adbc.
A Canyon render under a sky from Landscapes under Fantastic Skies
@ mermaid010 - beautiful render. I love the sky!
Hello dear Bryce friends,
this is my first attempt at an underwater scenery.
The corals in the foreground are trees. These I made after an tutorial from Horo.
Link: https://horo.ch/docs/mine/pdf/TreeStones.pdf
mermaid - the canyon looks very nice.
Rieke77 - very well done underwater scene.
Adbc, mermaid010, Horo, Rieke77, spuddy: Thanks.
Horo: nice lighting on those forms.
Spuddy: good work to use these strange colours for a tree object.
Mermaid010: nice terrain, good mood.
Rieke77: Very nice underwater render. Corals work very well.
A quick new abstract. I made another strange lens-item to go in front of a red cylinder. There is a radial light behind the cylinder and the whole scene is in a reflecting sphere. Rendering premium with true ambience and soft shadows (though those are not very visible in this scene). I modified a pre-made sky a bit to get the colours I wanted. It looks like part of a jet engine or so.
@ Horo and Hansmar - Thank you very much for your kind comments!
@ Hansmar - oh yes, it looks like an jet engine - great!
Hansmar - thank you. Cool abstract you came up with. Looks a bit like a aircraft engine.
Thanks Rieke, Horo and Hansmar
Rieke - beautiful underwater scene, well done.
Hansmar - awesome abstract, I'm fascinated by your lens effects.
Mermaid010..nice lighting on your Canyon render...
Rieke77..Lovely underwater scene I really like it great stuff
Hansmar..cool looking abstract like Mermaid010 I'm also facinated by your lens effects
Quick abstracty thingy trying things out again
spuddy, you have two abstract things. I don’t even know which one is better!
Spuddy - thanks beautiful abstract/still, the 2nd is my fav.
