Show Us Your Bryce Renders Part 11
13536384041100
  • spuddyspuddy Posts: 449
    edited June 2020
    Thought I would play around not..making landscapes ...bit rough and simple I know but thought I'd share anyway
    Tumbling Balls
    1754 x 875 - 3M
    Post edited by spuddy on
  • HoroHoro Posts: 11,705
    edited June 2020
    spuddy - looks very nice, a bit like spheres in a cave.
    Two identical terrains, one upside down on top of the other with different materials for the upper and lower terrain. Each lamp consists of three radials, two of them with different IES gobo to shape the beam, and an HDRI with only 60% shadow intensity to brighten the black shadows. This setup creates two different tunnels, the first has the camera to look into the left, the second into the right tunnel.
    Old Mine Left
    Old Mine Right
    1200 x 795 - 132K
    1200 x 795 - 133K
    Post edited by Horo on
  • mermaid010mermaid010 Posts: 6,280
    Spuddy - beautiful render,  I agree, looks like one of those ancient caves.
    Horo - the tunnel renders are awesome, interesting work
  • Tim82Tim82 Posts: 859
    awesome renders guys!!! ....great work :)
  • HansmarHansmar Posts: 3,226
    edited June 2020
    Mermaid010, Horo, Rieke77, spuddy, santi010, Tim82: Thanks very much.
    Spuddy: Nice abstract, with very nice texture in the background
    Horo: Interesting way of creating good looking tunnels.
    One advantage of an abstract is that a few changes, e.g. to the distorted lens and the sky, can give a totally different render. I also changed the human figure, for 'policy reasons'. I think, in the second render, I could have given her a different texture for the dress, but forgot about that.
    In the first one, I turned the lens around 180 degrees. In the second one 90 degrees and made it linger in the (new) y direction.
    875 x 875 - 798K
    1754 x 875 - 1M
    Post edited by Hansmar on
  • adbcadbc Posts: 3,115
    edited June 2020
    Hansmar : three very cool renders, I like them all.
    spuddy : agreed, looks like spheres in a cave.
    Horo : Great spooky tunnels.
    3 same canyon terrains based on downloaded height maps. The castle was also a free item.
    940 x 450 - 84K
    Post edited by adbc on
    edited June 2020
    Hansmar - awesome renders once again, the last one Lady Envy3 is my fav
    Adbc - wow beautiful render, the material and lighting blend very nicely
    Post edited by mermaid010 on
    edited June 2020
    mermaid and Tim82 - thank you.
    Hansmar - thank you. Again very cool looking abstracts through your specual lens.
    adbc - thank you. Great terraced landscape with the castle that blends perfectly into the surroundings.
    Same as above but both tunnels as seen through a wide-angle fisheye lens, 150° horizontal and 100° vertical. A tiny bit of the terrains had to be removed in the TE and the camera re-positioned.
    Old Mine Double
    1200 x 675 - 113K
    Horo - very nice effect with the fisheye lens
    mermaid, Horo : thank you.
    Horo : The effect with the fisheye lens is awesome.
    edited June 2020
    mermaid and adbc - thank you.
    The shapes are from the Hypertextures Base set and have a hypertexture material. Inside each one is a smaller copy with some reflection and transparency with a high refractive index. Lit by an HDRI that also comes with the Hypertextures set. The inside shapes create the dark shadows, the outer shapes the bright anti-shadow.
    Shapes Varied
    1200 x 800 - 217K
  • Rieke77Rieke77 Posts: 619
    @ spuddy - your Tumbling Balls looking great!
    @ Horo - wow, I like your tunnels. The third (fisheye) is my favorite.
    The image with the shapes are awesome.
    @ Hansmar - wonderful abstract renders!
    @ adbc - beautiful image!
    Horo..Mermaid010..Tim82..hansmar...adbc...rieke77... Thanky you all very much
    Horo  love all your posts the caves are great and the shapes are very sharp
    hansmar  love your alternative abstracts the last one is my favourite
    adbc.. Lovely render nicely put together
    edited June 2020
    still exploring things ... expressionism meets Bryce  Ha ha
    1754 x 875 - 3M
    Horo - Wow beautiful effect, I like the reflections
    Spuddy - a very nice paint-like render, so true expressionism meets Bryce, well done.
    Rieke77 and mermaid - thank you
    spuddy - thank you. You start to get the hang on Bryce. Very nicely done scene.
    @ spuddy - your expressionism render looks beautiful
    Horo : excellent render with the shapes.
    Rieke77, spuddy : thank you.
    spuddy : Expressionism is awesome.
    Thank you adbc.
    edited June 2020
    A Canyon render under a sky from Landscapes under Fantastic Skies
    900 x 675 - 354K
    @ mermaid010 - beautiful render. I love the sky!
    edited June 2020
    Hello dear Bryce friends,
    this is my first attempt at an underwater scenery.
    The corals in the foreground are trees. These I made after an tutorial from Horo.
    Link: https://horo.ch/docs/mine/pdf/TreeStones.pdf
    800 x 600 - 366K
    Post edited by Rieke77 on
    mermaid - the canyon looks very nice.
    Rieke77 - very well done underwater scene.
    edited June 2020
    Adbc, mermaid010, Horo, Rieke77, spuddy: Thanks.
    Horo: nice lighting on those forms.
    Spuddy: good work to use these strange colours for a tree object.
    Mermaid010: nice terrain, good mood.
    Rieke77: Very nice underwater render. Corals work very well.
    A quick new abstract. I made another strange lens-item to go in front of a red cylinder. There is a radial light behind the cylinder and the whole scene is in a reflecting sphere. Rendering premium with true ambience and soft shadows (though those are not very visible in this scene). I modified a pre-made sky a bit to get the colours I wanted. It looks like part of a jet engine or so.
    1754 x 875 - 447K
    @ Horo and Hansmar - Thank you very much for your kind comments!
    @ Hansmar - oh yes, it looks like an jet engine - great!
    Hansmar - thank you. Cool abstract you came up with. Looks a bit like a aircraft engine.
    edited June 2020
    Thanks Rieke, Horo and Hansmar
    Rieke - beautiful underwater scene, well done.
    Hansmar - awesome abstract, I'm fascinated by  your lens effects.
    edited June 2020
    mermaid010..adbc..horo..rieke77...hansmar,,,Thanks
    Mermaid010..nice lighting on your Canyon render...
    Rieke77..Lovely underwater  scene I really like it great stuff
    Hansmar..cool looking abstract  like Mermaid010 I'm also facinated by your lens effects
    Quick abstracty thingy trying things out again
    1877 x 722 - 3M
    1877 x 722 - 3M
  • SlepalexSlepalex Posts: 911
    spuddy, you have two abstract things. I don’t even know which one is better!
    Spuddy - thanks beautiful abstract/still, the 2nd is my fav.
