Problem with GPU rendering of DAZ' Private Pool
WandW
Hi Gang
I purchased Private Pool ( https://www.daz3d.com/private-pool ) the other day, loaded up the sample scene, added a G8 figure and rendered. It was taking a long time so I checked the log and it had an out of memory error for the graphics card (RTX 2060, 6 GB) and so was using the CPU.
Thinking I had too much stuff in the scene, I loaded the building prop alone, applied the iRay mat and rendered with Task Manager open. The GPU memory suddenly shot up to 6 GB, and it rendered a noisy stripe perhaps 30 pixels wide at the bottom of the image in 17 seconds.
I updated the drivers to 445.75 and tried rendering with OptiX Prime on and off to no avail. It doesn't seem like a very complicated scene to render, except perhaps the caustics of the water.
From the log file; Studio 4.12.0.86
2020-04-02 21:44:13.945 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:2020-04-02 21:44:13.945 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce RTX 2060): 4999 iterations, 79.450s init, 1.338s render2020-04-02 21:44:13.945 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CPU: 1 iterations, 78.618s init, 15.024s render2020-04-03 14:16:02.213 Rendering image2020-04-03 14:16:03.107 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\11_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.126 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\11_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.144 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\11_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.151 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\11_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.154 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\11_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.238 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\13_Opacity.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.266 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\13_Metallic.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.281 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\13_Roughness.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.299 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\13_BaseColor.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.308 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\13_Normal.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.313 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\13_Height.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.339 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\13_Emissive.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.366 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\10_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.373 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\10_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.380 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\10_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.382 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\10_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.384 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\10_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.394 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\12_Opacity.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.409 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\12_Metallic.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.414 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\12_Roughness.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.421 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\12_BaseColor.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.426 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\12_Normal.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.428 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\12_Height.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.433 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\12_Emissive.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.2020-04-03 14:16:03.447 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\02_Opacity.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.459 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\02_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.470 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\02_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.478 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\02_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.478 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\02_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.479 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\02_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.492 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\09_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.504 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\09_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.515 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\09_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.516 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\09_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.517 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\09_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.520 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\06_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.521 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\06_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.522 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\06_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.523 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\06_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.524 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\06_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.526 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\07_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.527 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\07_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.529 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\07_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.529 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\07_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.530 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\07_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.533 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\08_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.534 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\08_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.535 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\08_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.536 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\08_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.537 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\08_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.540 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\04_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.541 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\04_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.542 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\04_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.543 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\04_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.544 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\04_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.546 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\05_Opacity.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.547 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\05_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.548 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\05_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.549 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\05_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.550 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\05_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.551 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\05_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.554 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\01_Metallic.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.555 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\01_Roughness.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.556 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\01_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.557 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\01_Normal.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.558 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\01_Height.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.561 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\03_BaseColor.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.588 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\PoserLibrary\DAZ Content\Runtime\Textures\Mely3D\Private Pool\03_Emissive.jpg", pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.2020-04-03 14:16:03.772 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "D:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.2020-04-03 14:16:04.431 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.2020-04-03 14:16:04.432 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.2020-04-03 14:16:04.473 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)2020-04-03 14:16:04.473 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 02020-04-03 14:16:04.511 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 object with 189k triangles, 1 instance yielding 189k triangles) took 0.038s2020-04-03 14:16:04.511 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.2020-04-03 14:16:04.538 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__11_313_436' uses MDL JIT compilation.2020-04-03 14:16:04.542 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__13_314_451' uses MDL JIT compilation.2020-04-03 14:16:04.544 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__10_315_472' uses MDL JIT compilation.2020-04-03 14:16:04.548 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__12_316_487' uses MDL JIT compilation.2020-04-03 14:16:04.549 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__02_317_508' uses MDL JIT compilation.2020-04-03 14:16:04.551 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__09_318_525' uses MDL JIT compilation.2020-04-03 14:16:04.553 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__06_319_540' uses MDL JIT compilation.2020-04-03 14:16:04.555 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__07_31a_555' uses MDL JIT compilation.2020-04-03 14:16:04.557 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__08_31b_570' uses MDL JIT compilation.2020-04-03 14:16:04.559 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__04_31c_585' uses MDL JIT compilation.2020-04-03 14:16:04.560 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__05_31d_600' uses MDL JIT compilation.2020-04-03 14:16:04.563 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : Material instance 'DS_Private Pool__01_31e_617' uses MDL JIT compilation.2020-04-03 14:16:04.563 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 111 textures, 12 lambdas (12 unique)2020-04-03 14:16:04.583 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (3 light sources with 124k triangles, 1 instance) took 0.016s2020-04-03 14:16:04.583 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment.2020-04-03 14:16:04.623 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate.2020-04-03 14:16:04.627 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lens.2020-04-03 14:16:04.627 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.2020-04-03 14:16:04.627 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.2020-04-03 14:16:04.627 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.2020-04-03 14:16:04.627 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.2020-04-03 14:16:04.628 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER :: 1.0 IRAY rend warn : The 'iray_optix_prime' scene option is no longer supported.2020-04-03 14:16:04.657 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer2020-04-03 14:16:04.667 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using batch scheduling, caustic sampler disabled2020-04-03 14:16:04.667 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing local rendering.2020-04-03 14:16:04.674 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CPU: using 5 cores for rendering2020-04-03 14:16:04.675 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 2 device(s):2020-04-03 14:16:04.675 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce RTX 2060)2020-04-03 14:16:04.675 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CPU2020-04-03 14:16:04.675 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...2020-04-03 14:16:04.676 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : Initializing Embree2020-04-03 14:16:04.677 Iray [VERBOSE] - IRAY:RENDER :: 1.4 IRAY rend progr: CUDA device 0 (GeForce RTX 2060): Processing scene...2020-04-03 14:16:04.678 Iray [VERBOSE] - IRAY:RENDER :: 1.6 IRAY rend progr: CPU: Processing scene...2020-04-03 14:16:04.728 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : Initializing OptiX for CUDA device 02020-04-03 14:16:04.728 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Geometry memory consumption: 6.03765 MiB (device 0), 0 B (host)2020-04-03 14:17:27.147 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : Importing lights for motion time 02020-04-03 14:17:27.183 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : Initializing light hierarchy.2020-04-03 14:17:33.234 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Texture memory consumption: 4.55273 GiB for 68 bitmaps (device 0)2020-04-03 14:17:33.293 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : Light hierarchy initialization took 6.110s2020-04-03 14:17:33.306 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Lights memory consumption: 13.6453 MiB (device 0)2020-04-03 14:17:33.345 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Material measurement memory consumption: 0 B (GPU)2020-04-03 14:17:33.539 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : Materials memory consumption: 57.5117 KiB (GPU)2020-04-03 14:17:33.539 Iray [VERBOSE] - IRAY:RENDER :: 1.7 IRAY rend stat : PTX code (89.2 KiB) for SM 7.5 generated in 0.225s2020-04-03 14:17:33.544 Iray [VERBOSE] - IRAY:RENDER :: 1.2 IRAY rend stat : Native CPU code generated in 0.240s2020-04-03 14:17:33.783 Iray [INFO] - IRAY:RENDER :: 1.6 IRAY rend info : CPU: Scene processed in 89.106s2020-04-03 14:17:33.799 Iray [INFO] - IRAY:RENDER :: 1.6 IRAY rend info : CPU: Allocated 21.3267 MiB for frame buffer2020-04-03 14:17:34.053 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : JIT-linking wavefront kernel in 0.269s2020-04-03 14:17:34.071 Iray [INFO] - IRAY:RENDER :: 1.7 IRAY rend info : JIT-linking mega kernel in 0.018s2020-04-03 14:17:34.072 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : CUDA device 0 (GeForce RTX 2060): Scene processed in 89.396s2020-04-03 14:17:34.127 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER :: 1.4 IRAY rend error: CUDA device 0 (GeForce RTX 2060): out of memory (while allocating memory)2020-04-03 14:17:34.129 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER :: 1.4 IRAY rend error: CUDA device 0 (GeForce RTX 2060): Failed to allocate 739.319 MiB2020-04-03 14:17:34.132 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : CUDA device 0 (GeForce RTX 2060): Allocated 21.3267 MiB for frame buffer2020-04-03 14:17:34.134 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : CUDA device 0 (GeForce RTX 2060): Allocated 4.64063 MiB of work space (5k active samples in 0.000s)2020-04-03 14:17:34.134 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : CUDA device 0 (GeForce RTX 2060): Used for display, optimizing for interactive usage (performance could be sacrificed)2020-04-03 14:17:34.211 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : Allocating 1-layer frame buffer2020-04-03 14:17:34.371 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - POST:RENDER :: 1.0 POST rend error: A CUDA error occurred: out of memory2020-04-03 14:17:34.372 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - POST:RENDER :: 1.0 POST rend warn : Failed to allocate device memory, falling back to CPU2020-04-03 14:17:34.476 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00001 iterations after 89.801s.2020-04-03 14:17:34.511 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER :: 1.0 IRAY rend warn : The 'iray_optix_prime' scene option is no longer supported.2020-04-03 14:17:34.513 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00002 iterations after 89.838s.2020-04-03 14:17:34.671 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00004 iterations after 89.995s.2020-04-03 14:17:34.775 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00008 iterations after 90.100s.2020-04-03 14:17:34.895 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00016 iterations after 90.219s.2020-04-03 14:17:35.402 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00032 iterations after 90.726s.2020-04-03 14:17:35.890 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00064 iterations after 91.214s.2020-04-03 14:17:36.359 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00256 iterations after 91.683s.2020-04-03 14:17:36.775 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 02944 iterations after 92.099s.2020-04-03 14:17:37.351 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 04999 iterations after 92.676s.2020-04-03 14:17:51.507 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 05000 iterations after 106.832s.2020-04-03 14:17:51.507 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Maximum number of samples reached.2020-04-03 14:17:51.850 Saved image: C:\Users\Rod\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png2020-04-03 14:17:51.872 Finished Rendering2020-04-03 14:17:52.124 Total Rendering Time: 1 minutes 50.18 seconds2020-04-03 14:17:52.137 Loaded image r.pngThanx for any insights, as it is an interesting product I'd like to use without overnight renders...
No one else had any problems?
This is what happens memory wise when I try to render it...
Hi,
I just loaded the Private Pool sample scene and hit Render: no out of memory error that I can see (2080Ti).
It is suuuuuuper slow to render (like 3 iterations per minute), but it seems to be using the GPU.
Still too slow for me unfortunately.
I'm interested in knowing if it works fine for anyone!
Do you have 8 GB on your card? I have a 2060 which has 6 GB
Edit; I'm tried it CPU only and am gettting about 4 iterations per minute...
I have 11Gb.
Wow.
I can see why I run out of memory on somemething like C3D'd Long Island mansion with all of those textured walls and doors, but this scene is basically a few boxes...
Geometry uses relatively little VRAM. Textures use a lot. For some reason this set includes 8k textures for everything. You can cut almost all of those down to 1k with no loss of visual detail.
The problem with reducing texture size is when you open that scene something like 2 years later, on a different PC: it won't find any texture.
It would be better to have standard sized textures with the products, also because the product library gets bigger and bigger, no point in taking more storage than necessary.
Except that when you have high res textures you can downsize them, but if you only have lower res textures you can't make them higher res if you need a closeup. So if only one version is included it's better to provide the high resolution one as it will be more versatile.
@LenioTG "when you open that scene something like 2 years later, on a different PC: it won't find any texture."
There are several simple ways to deal with that problem.
`The product says it includes textures from 512 to 8k. If you just the provided textures DS will have no trouble finding them.
I looked in the texture folder and except for small things things like plant leaves and such, mostly they are are 8K maps, two being over 20MB...
then you'll need Scene Optimizer to get it down to a manageable size.
If that's the case, DAZ should put Scene Optimizer as a required product...
@WandW "If that's the case, DAZ should put Scene Optimizer as a required product"
Just because it drops to cpu on your card doesn't mean it won't render on more capable GPUs. You have the low end RTX after all and no more Vram than a 980TI.
boubakeurjohn in the third post appears to have it drop to CPU on his 2080Ti; either that or my CPU is rendering it faster than his GPU......
It wouldn't be the first product released that wouldn't render on an 11Gb card. I've gotten refunds on a couple because of that.
This PA tends to go nuts with memory requirements. I had issues with their Behind the Scenes product. One hint as to which sets may cause problems like this is if the promo renders don't include any characters. If the PA is able to fit in characters, you probably will be, too. That's not any kind of sure thing, but it is a red flag. Sets look a lot better if they are shown populated with figures. On the other hand, Ultrascenery renders really easily but the promos aren't populated. BUT! It is used in dozens of renders in the Gallery, while the Private Pool isn't referenced by any gallery images at all.
Anyway, I own this pool set, and will give it a whirl after my current render finishes.
So, I loaded up the scene and went to render the sample scene provided with nothing but the set in the scene. I was left with 12% memory on my 8 Gb GPU. That's not enough for a haired & clothed character. Textures took up 4,8 Gb, which is a whoe lot for an empty set. After using Scene Optimizer on only the 8k maps, leaving the others at 4k, that came down to 1.4 Gb. The biggest culprits were the 20 Mb normal maps, twice the size of the diffuse maps. That's just silly for the kind of scene it is. Were you stricken by the fine texturing in the promos? Neither was I. I mean if the Red Crow Inn can get by with 4k maps, then this bikini background should be able to, as well.
Anyway, if anyone doesn't have Scene Optimizer, Irfanview has a batch resample tool, and it's free. Might as well save yourself some disk space while you're at it, and overwrite the originals.
It's an okay set, which is why I bought it, although IIRC it was part of some sale get-it-for-3-bucks promos we had during March Madness. It's not something I'd pay release dollars for. But geez, PAs need to remember that most of their customers are hobbyists and don't run 24 Gb rigs. And since it's a DO, Daz should have known better, too.
I attached the scene intended to showcase those 8k maps. This is after reducing them to 4k. Whatever.
hello, thank you very much for purchasing Private Pool and I hope you find this product useful.
I just wanted to give you my opinion and some information on the size of the textures.
When you work on a project (game, movie, pub etc) you know at the start the size of the textures that you will need for the environment or the scenes in which your product will be used.
On the other hand when you make a product which you sell on a shop like on DAZ3d you do not know what use the customers will have of your products.
They are going to make wide shots, close ups, you don't know.
Not knowing, I prefer to provide larger textures in an attempt to respond to both possibilities.
For those who do not need large textures it is very easy to resize the textures for the use they have. It would be more difficult for those who need large size to enlarge too small textures
It's a choice and I assume it!
ah, and no i don't go crazy ....
Do you think it is necessary for a wide shot to have a texture for the head of 4096X4096 or even a texture of 2048X2048 for teeth? I think not, but the day you need to do a close-up you will be happy to have them, same for the Private Pool
As for the space taken up on the hard drive, I don't think that is a good review. Given the price of hard drives these days .... (and it is very easy to remove duplicates after your renderings)
You can also use (as on the image of the pst above) the image compression provided with Iray, but that risks giving bad results as we can see on the image above.
If someone needs help to use my products do not hesitate to contact me, I am very rarely on the forum but I answer all the time, normally .....
Voila, I hope I have clarified something
And sorry if there are errors but English is not my native language
Keep well!
Thanks for responding. The issue isn't space on the hard drive, but GPU memory used by the maps.
It would have been nice to have lower resolution textures also included as a choice, rather than having to create them manually or purchase an additional product in order to have scenes utilize the GPU when rendering. The average user doesn't have lots of GPU memory, (I just recently upgraded to a 6GB card from 4GB) and there is no minimum hardware requirement listed in the product description...
