Problems with Zeddicuss G8F poses
I am having a lot of problems with this venders poses lately, when I choose a selection it results in either a slightly changed A pose or the body joints are all mangled. I am making sure I choose G8f selctions also. These sets I have tried https://www.daz3d.com/z-sci-fi-light-swords-mega-set, https://www.daz3d.com/z-combat-rifles-and-poses-for-genesis-3-and-8, https://www.daz3d.com/z-animalistic-poses-and-partials-for-genesis-3-and-8, https://www.daz3d.com/z-sci-fi-weaponry--props-and-poses-for-genesis-3-and-8. I have many more by this vender I have not tried yet because frustrated I waited to long to try them now I can not return them
  • nemesis10nemesis10 Posts: 4,056
    I have almost  all of those have have not had these problems.  How do you install and how do you verify that you are using the G8F pose?
  • jedijuddjedijudd Posts: 606
    I install with DIM, I look at what the icon says G8F
    edited June 2020
    I have all of those except for the combat rifle poses, went through every G8F pose, and they all work for me.  I think the first thing I would try is to right click on the pose to browse the the proper location for the file and make sure it is showing in the appropriate character's  library or better yet, load your figure and apply the pose from the library so that you are certain you are getting the G8F pose instead of the G3F pose. Also, select the pose in Smart Content or Library and look to see what it says in the Info tab.  Zeddicus is pretty prolific and I haven;t heard of this as a problem.  Here is a render showing a pose properly applied.
    1610 x 1162 - 466K
    Post edited by nemesis10 on
  • N-RArtsN-RArts Posts: 1,609
    edited June 2020
    I've got the same problem, but with different sets (I don't own any of those). At times, it's like the joints "lock".
    The first pose that's loaded works fine, but any poses loaded on the same model after that, just "don't work". Then I have to "zero figure pose" in Parameters to clear the pose and start again (I hope that makes sense).
    I didn't create a post about it, because I've had quite a bit of trouble with Daz Studio, and the computer that I use it with/on.
    Post edited by N-RArts on
    Thanks Ill try those tips and see if it works
  • jeru009jeru009 Posts: 1
    edited April 2021
    I'm actually having the same problem I know this thread is old but can anyone offer advice? I own a few of the Z poses and they work just fine, recently I ordered the smokers pack. and villain poses and they don't work at all. Never mind I figured it out my bad, I'm a newb don't hold it against mesmiley
    Post edited by jeru009 on
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    edited April 2021
    In case you are experiencing the known issue where poses or expressions don't properly clear when you add another pose or expression, and instead sort of "stack," this product works wonders:  https://www.daz3d.com/ultimate-zero  ;
    But if you are having this issue you describe only with Zevo poses, then you have a different issue.
    Post edited by Worlds_Edge on
  • Zev0Zev0 Posts: 7,123
    I don't do poses...Think you mean Zeddicuss.
     Not sure if this was mentioned since I kinda skimmed through the thread quickly as I am about to go to bed, but have you tried leaving Limits ON?
    Sometimes limbs that are mangled as you stated are due to either leaving Limits ON or OFF and PAs typically state which of the two to use with their pose sets.
    Hopefully this helps :)
    Adjust rigging to shape if the figure is significantly changed from the base figure.
  • Most pose issues are limits related-- either left on or off depending. That and the stacking poses issues are the big ones. But 9/10 it's limits.
