Separate render of model and hdri
Hi all, I ve been wondering, is there any way how to separating the final render of model and hdri image?? With "one click" render, i want to have 2 different picture. 1 is for the model, and another one for hdri image...the reason for this is so i can have full control when i edit it in potoshop Iam newbiee, please be understand. cheers
  • Leonides02Leonides02 Posts: 1,379
    Yes! You need to use the Iray canvases feature. Set the model as its own "beauty" canvas.
    In the render settings tab, under Environment, look fors "Draw Dome"
    Off means it will not render the HDRI image for a background but it still lights your scene as if it does
    On means you see it in the render.
    So do a quicky of just the dome and then do a second with the character and other content.
    Then you can combine them in PS
  • @leonides02 wow never heard about it.... Let me try it...thanks
  • @Mattymanx yes, i often use this method, but my computer spec is not really high, its often freeze for some time after 1 render, and need to wait for several minutes before i can do the second render. I prefer to have 2 image render in 1 click. But thanks for your comment
