Separate render of model and hdri
Hi all, I ve been wondering, is there any way how to separating the final render of model and hdri image?? With "one click" render, i want to have 2 different picture. 1 is for the model, and another one for hdri image...the reason for this is so i can have full control when i edit it in potoshop Iam newbiee, please be understand. cheers
  • Leonides02Leonides02 Posts: 1,379
    Yes! You need to use the Iray canvases feature. Set the model as its own "beauty" canvas.
  • MattymanxMattymanx Posts: 7,000
    In the render settings tab, under Environment, look fors "Draw Dome"
    Off means it will not render the HDRI image for a background but it still lights your scene as if it does
    On means you see it in the render.
    So do a quicky of just the dome and then do a second with the character and other content.
    Then you can combine them in PS
  • @leonides02 wow never heard about it.... Let me try it...thanks
  • @Mattymanx yes, i often use this method, but my computer spec is not really high, its often freeze for some time after 1 render, and need to wait for several minutes before i can do the second render. I prefer to have 2 image render in 1 click. But thanks for your comment
