• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz3d to Blender Workflow
«1234567…10»
  • j cadej cade Posts: 2,310
    May 2020 edited May 2020
    So have all y'all animation folks tried this out? Its a pretty basic retargeting plugin
    The target figure in the example is even a Daz figure.
    I tried it out and got it to work pretty well despite knowing next to nothing about animation. I now have Gen 8 dancing to a animation from Mixamo. Blender 2.9 has also improved strand dynamics apparently so I'm having all sorts of fun experimenting
    Behold the majesty!
    I'm calling it a skirt posessed
    Post edited by j cade on May 2020
  • aelghaziaelghazi Posts: 45
    May 2020
    benniewoodell said:
    aelghazi said:
    benniewoodell said:
    aelghazi said:
    benniewoodell said:
    aelghazi said:
    this a cycles one frame render thaat took me 8 minutes to render, you can see the results are amazing, way better than an fbx import, of course I played a bit with nodes and lighting bulet me know if iott I just see it very difficult to get same result from an fbx file.
    @aelghazi that image looks fantastic! The video also looks amazing, I'm so glad you got it all to work!
    @Padone, or anyone that might have come across this, I hope someone can help me out here. This week has been insanely busy and I'm sitting down to relax a bit and wanted to see what some of my shots for my animated short would look like in Cycles now that the animation is done and I'm just waiting for the actors to send me their audio, and if I see that it can help my film, I'm going to re-render it all in Cycles while I'm working on the audio and use what I have as the temp track. I went ahead and downloaded the newest version of the Diffeomorphic tool as well, so it's the development version 1.4.2. Now, the girl looks stunning in cycles for the reverse angle, but the guy I'm having some difficulty with and I don't know what the problem is. As you'll see, in the shot that's got the background and her in it, that was in Eevee and the hair is exactly how I exported it in Daz. But when I kick it over to Cycles, now the hair isn't shaved on the side anymore and his eyelashes look to be squares over and under his eyes. I've sat here for the past three hours or so trying to putz around in the shading and UV Editing tab trying to see if I could find the culprit, but nothing came of it, I can't get the shaved sides. And there's even a material set up in the material tab called SamuraiBun_Shaved-1. I checked every node and nothing worked. So I'm just wondering if this is something you've run across or not. It's not the end of the world, it's not going to break the film if I can't have the sides shaved, but aesthetically I like it better.
    Thanks so much for any help in this matter!
    ive got some improvement for sure for my anymations and shading node setups ,better but still not as I wated to be.
    Ah ha, max bounces! I will give this a try after this shot I'm doing renders and see if the max bounce is the culprit. I do know I have it set to 4 as I had read earlier today from Blender Guru that he just sets it to four and generally it's fine to speed up Cycles renders. But if it's going to affect hair like that, I shall boost it back up! Fingers crossed it works.
    And keep at it, you'll get it to where you want it to be for sure. That's the joy of all this, it's a constant learning experience. Every day, every project brings about a new challenge to figure out, keeps the brain on it's toes :)
    let me know if it works .
    It worked! I had to jack the max, transmission, and transperency bounces up to 200, but it finally got rid of the hair enough! Great call, thank you so much!
    perfect, we are all waiting for your cloth simulation tutorial.
  • PadonePadone Posts: 3,995
    @aelghazi When you import the daz morphs some bones may get drivers so you can't move them anymore. That's the way daz do things, the genesis rig is quite complex as for morphs and driven bones dependencies. To fix this you can use the "make all bones posable" tool, that will give you an extra layer of bones you can always pose.
    http://diffeomorphic.blogspot.com/p/corrections-section.html
    p.s. Your video is nice I like it, then the comments by @wolf359 may push you to do even better.
    @benniewoodell As for the development version, the diffeomorphic plugin warns you if your cycles settings are outside some minimum requirements including refraction and transparency. This only happens when you import the scene though, so if you import with eevee you get to bypass the warning.
    http://diffeomorphic.blogspot.com/2020/04/render-settings.html
    Nevertheless the plugin only checks for minimum requirements and some scenes may need more. As a general rule if you get strange artifacts in your renderings then you may use the "full global illumination" preset in cycles to check if the issue is in your render settings.
    @jcade Love that fluffy skirt smiley. Also the addon seems very interesting I like the ik retargeting feature for hands and feet, thank you for pointing that out.
    Post edited by Padone on May 2020
  • hookflashhookflash Posts: 169
    May 2020
    Fyi, Diffeomorphic also makes a BVH retargeting plugin that, in my brief tests, works really well with the DAZ Importer: https://diffeomorphic.blogspot.com/p/bvh-retargeter.html
    The guy is some kind of benevolent genius!
  • nicsttnicstt Posts: 11,715
    May 2020
    aelghazi said:
    I hope I can develope my skills so I have an excuse to upgrade my laptop to a nice RTX 2080ti tower or next gen RTX maybe. At the moment still want to see the results of the facecap and face mojo plugins and see if a small short film can be achieve with a nice quality and details. More techniques I have to learn such as simulations ( fluid and cloth) and general composition in blender, realism is important for me , i am sad I have to use eevee instead of cycles but no possible with my laptop. yes I chosed the easy way to animate my character and take it back to blender, but was not easy to find that workflow and at least it worked thanks to diffeomorphic.
    I recomend you guys to see what the facecap is capable of its impresive and this character is so impressive the details, I am sure some daz characters are so realistic if they are tweeked in blender, but that facecap thing is impressive.
    One of the reasons (and likely the main one) is that getting stuff over to Blender will allow me options other than using the 'almost enforced' requirement for a Nvidia card; sure you can manage without, but it is painful.
    May 2020
    Behold the majesty!
    Yeh, 2.9 looks amazing; I like the improvements to the Multiresolution Modifier.
  • benniewoodellbenniewoodell Posts: 1,999
    May 2020
    @Padone I see, that makes sense as Blender just defaults to Eevee for me when I open it up and so I've never seen that warning, good to know. Plus everything I'm trying to render right now I've already animated and rendered in Eevee, I'm not actually bringing anything new in. But later today I'll try just to see what happens when I load a character in with Cycles selected. It looks really good rendered out.
    @aelghazi I'm so sorry for the delay in the cloth sim tutorial, the past week has been jam packed. I'll make some time later today to do it!
    May 2020
    thank you Bennie, take your time, I am trying to render a new type of HD character, it took me 15 minutes to render one single frame , thats just no possible for an animation, it will take days, I tried to reduce some cycles settings to lower the render time but just it doesnt look good, with eevee looks even worst , I tried to play with the nodes but it doesnt work, did you guys realised every character is bein imported with diffeo with different shading nodes and it makes it very hard to know what you have to touch. I tried e-cycles version of blender, doesnt make a big difference in render time. Maybe I am very limited now with the GTX 1060 for the type of realism I wanna achieve. Damn those expensive graphic cards.
    May 2020
    You know, I noticed some characters' skin transfers beautifully and others not so much. What I did once, and it worked, if you have the G8 to Maya plugin, export the character with that and you'll get a folder that has all the texture maps you've set up. For whatever reason the tattoos I had set up weren't being brought over so I tried this method. When I did this, I didn't know what any of the nodes were, so I deleted it all and just brought the maps in and connected to the color node of the Principle BDSF and it totally worked, the character looked wonderful. If you don't have the Daz to Maya 8 plugin, I don't know how else you'd get the textures out, I'm sure there's a way. Now I'm just making personal notes of skins that look wonderful and ones that absolutely don't and just switch the skins to ones that work in Daz before bringing them over.
    May 2020
    I will try to find that plugin and try, just texture nodes connected to principle BSDF ? it looks so easy setup, no mapping node , mix shader, nothing ? ok I give it a try? but was it rendered in eevee or cycles ? becaude for me this new HD character I am trying looks amazing with cycles, but eevee, is a joke.
    May 2020
    Sometimes they have it on sale for like 25 bucks or something like that, I think that's how much I spent on it.
    But yeah, I just connected the jpg map to the color node in the Principle BDSF, I didn't add anything else. But that was a couple of months ago when I did this, so now I would try to work with the other nodes to make it better now that I know more of what's going on. I did it on Eevee because the whole reason I wanted to go into Blender was for Eevee and the real-time rendering. I'm about to do an animated feature and don't want to spend two years rendering. The animated short I just I did, the shots were rendering faster than I could go and get a drink and sit back down. Does it look as good as cycles? No, but I'm also doing more anime style so it works great for what I need.
    May 2020
    I am rendering a 250 frames in cycles of an HD pirate female, I had to lower a lot the settings in cycles to be able to get 6 minutes per frame, otherwise in setting by default was like 15 minutes per frame, 6 minutes is still a lot but I am expecting a good result. I will share once is ready, maybe after 12 more hours.
  • wolf359wolf359 Posts: 3,929
    May 2020
    12 hours for 250 frames???
    Not much of an improvement over Iray.
    May 2020
    maybe but I can use blender at least and composite the model there. the goal here is not to render the character only, is to use the character in a composition in blender as daz is very limited .
    @aelghazi @benniwoodell
    As for HD characters they don't fit animation you need to bake the HD geometry to a normal map. The diffeomorphic plugin imports HD characters to get a base for baking. Though they can also be used for rendering since the iray materials are preserved.
    As for materials conversion if you want the principled shader you can just switch off the auto material option and select the principled option for both the opaque and refractive materials. The default values work best for cycles.
    http://diffeomorphic.blogspot.com/p/settings-panel_17.html
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    May 2020
    And there is little reason to expect one, since they are both non-biased render engines, if you have an Nvidia card to use.  You do have more levers to pull with Cycles to get better performance, but you must expect to spend time working out which ones work best.  With Iray you seem to have only one really effective lever - buy a 'better' Nvidia graphics card.
    People moving to Blender mainly for improved render times should surely be using EEVEE, and shouldn't expect the results to look exactly like Iray (or Cycles), though they can look very good.
    May 2020
    Well that is my point actually.
    Cycles by default is a brute force path tracer much like Iray except that it has "branched mode" that allows the user to individually set parameters on a per material type basis and other optimizations such as the number of bounces for reflective surfaces etc.
    The Mistake, I am seeing, is that people seem to think that they can escape the unidirectional"buy a bigger$$NVIDIA$$ card" solution of Iray.
    So they flee over to Blender and faithfully replicate the IRay experience right down to ridiculously hardware intensive volume based Subsurface scattering and 4K textures , Ultra hi-res figure geometry and NONE of the Branched path tracing optimizations, yet expect the mighty Blender to magically out perform IRay....for ANIMATION. RENDERING no less .
    This is not how the technology works.
    May 2020
    Hello guys, again, the only reason why we want to move to blender is because we are doing the final composition in blender and we want to use more things like particule simulations or other assets, things that are better done in blender than daz, we are not importing our character just because we want a better render time, we all know that eevee wont look as good as ray trace engine however I guess we still have to render in blender once the composition is done right ? ;)
    May 2020
    PS : I understand if your only goal is to renter one image and one pose and you are looking for realism, dont use diffeo and dont bother to rennder using other 3D app just stay in daz, but for the ones looking for realism and more complex scenes to make, then there is no point to stay in daz, only use daz to make a character or a scene and then work it out in Blender.
    May 2020
    That is the exact reason I do not render in Iclone even though I create all animation there.
    May 2020
    wolf359 said:
    wolf359 said:
    note that iclone, cc3 or 3Dxchange doesnt accept some type of characters, for example the bobot female showed in my video that was impossible to import in reallusion apps, maybe because the geoshells or HD characters , I was trying to import her in iclone for month but failed ,but with normal characters it works, so I had to find a different workflow.
    May 2020
    It does not really matter where you create your animation
    If you are using Hi resolution characters in Blender, imported Via Diffeo, with 4K textures and Volume based SSS to emulate Iray materials, your peformance/render times per frame will not be signifigantly better than Daz studio Iray even with a single naked character in an empty universe to say nothing of a complex Blender environments with hair and cloth simulation etc.
    Having completed a 92 minute animated film with Iclone /DAZ studio Raytraced in Maxon C4D, I can assure that animated filmaking is about optimization particularly if you are working alone and not using a render farm service.
    For the record, I think Diffeo is a great asset in fact I use it to import my figures into my Blender scenes to harvest the excellent Shader node setups it generates and apply those to the same figures brought in from Iclone via FBX or Alembic.
    However I use EEVEE because I am only willing to accept a render time of a few seconds per frame as I plan on doing a WEEKLY animated web series where 12 hours for for 250 frames is completely impractical.
    @aelghazi @wolf359
    As for rendering speed of course eevee is a new class by its own though it has limitations over cycles. Also I agree the branched path tracing is a faster way by itself. The single sample is slower but we need far few samples to converge so overall it's faster.
    Nevertheless I believe the strongest point of cycles is its denoiser. Compared to iray it needs far few samples to denoise. That's because cycles uses the albedo and displacement buffers to retain details while iray only relies on ai so to me it's more an advanced blur than a real denoiser. External denoisers can't help either because with the iray lpes we can't export the albedo and displacement buffers for them to work fine.
    May 2020
    finally after almost 24 hours rendering this short anymation in cycles where I lowered the render from 128 to 16 and the bounces to the lowest I could. To be honest is more real than eevee but I am not either happy with the animation and the render quality and the timing, for the animation I guess with a facial mocap will be smoother and less mechanic as this one where I just baked some aniblocks, and I guess to be able to render in cycles I need definetly a new GPU, I tried to play with the nodes in eevee but didndt help, thats why I ended rendering in cycles. Let me know what do you think.
    https://www.youtube.com/watch?v=0oCIwTjfEho&feature=youtu.be
    @aelghazi The rounded teeth are horrible cheeky please use the development version. Also you didn't use the denoiser. Then 24 hours for a ten seconds animation at 16 samples seems a bit odd to me. That's about five minutes per frame if you render at 30 fps. Are you sure you're rendering with the gpu ? May be you need to use the simplify panel to fit the scene to the vram. Though a single character should fit without.
    You can check the gpu and vram usage in the task manager.
    May 2020
    yes the teeth are horrrible, is the development version will fix the teeth ? I didnt use denoiser because the render was taking even more for a single frame, yes I am using GPU, is quite a lot, what is the simplify panel ? its about 3.8 gb of vram, it should not had taken that long on a GTX 1060 specially at that low quality. Any tips ?
    May 2020
    aelghazi said:
    Padone said:
    @aelghazi The rounded teeth are horrible cheeky please use the development version. Also you didn't use the denoiser. Then 24 hours for a ten seconds animation at 16 samples seems a bit odd to me. That's about five minutes per frame if you render at 30 fps. Are you sure you're rendering with the gpu ? May be you need to use the simplify panel to fit the scene to the vram. Though a singlwell is weird, the task manager is saying abovee character should fit without.
    well its weird, the task manager is saying 6900 mb at 76% and cpu 100% but in the render panel in blender Im rendering in gpu and it says memory 4100 mb and peak 4100 while rendering, what does mean all this that is different from task manager ?
    May 2020
    is it because in system preference in blender I have checked both cpu and gpu in cuda ?
    May 2020
    I unchecked cpu in blender and left only gpu in cuda, and chose gpu in cycles but in the task manager while rendering, is showing only 6% gpu and 12% cpu but 88% memory  , any idea whats going on ?
    May 2020
    it should be 100 % gpu in the task manager
«1234567…10»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
