please can someone help this is so frustrating
13»
  • Dim ReaperDim Reaper Posts: 687
    ok i ran that techno and yes it using almost 7 gig
    7GB when rendering just a sphere sounds very high.  What was the GPU load showing?
  • lasagnamanlasagnaman Posts: 1,001
    no no not the sphere the last scene i made use almost 7 gig
    i had 3 people and a farmhouse snd some props that used 7 gig
    ok the sphere uses 2 gig of memory is that normal
    i am sorry i was wrong it uses 324 mb
  • Kevin SandersonKevin Sanderson Posts: 1,643
    Windows takes a chunk of your 8 gigs and Iray takes some too. Your 7 gig easily would run over. Resize/compress your textures, etc. You don't need 4K of textures for each character if they aren't in close up, and then you could always do with less.
  • lilweeplilweep Posts: 2,802
    What's the best way to compress textures without doing it manually for each one?
