Problem with IM00069753-01_NowCrowdBillboardsSailingtheSevenSeas01of14
in The Commons
Allo
Someone have notice checksum error on this first file of 14 for Nowcrowbillboard Saillingthe sevenSeas ? the others files 02, 03.....o14 are ok
I have downloaded three times the file and Winrar (paid version0 display a message about error on the file ; see capture screen
what can i do for this
Thanks
Submit a help request
Can you extract the zip using 7zip?
I have tried with 7 zip and Winzip Same result : error on the file
Here screencapture for winzip
I have download again same error
Note that all other files of the product are ok with Winrar Only the 01 is problematic
What happens if you try to download and install that file with DIM?
Thank Sevrin for your suggestion .I have installed the product using DIM correctly
Normally i don't prefer to use DIM but thi time it was a solution
