Problem with IM00069753-01_NowCrowdBillboardsSailingtheSevenSeas01of14
MartialMartial Posts: 431
Allo
Someone have notice checksum error on this first file of 14 for Nowcrowbillboard Saillingthe sevenSeas ? the others files 02, 03.....o14 are ok
I have downloaded three times the file and Winrar (paid version0 display a message about error on the file ; see capture screen
what can i do for this
Thanks
1320 x 726 - 462K
    Can you extract the zip using 7zip?
  • MartialMartial Posts: 431
    I have tried with 7 zip and Winzip Same result : error on the file
    Here screencapture for winzip
    I have download again same error
    Note that all other files of the product are ok with Winrar Only the 01 is problematic
    1920 x 1200 - 308K
  • SevrinSevrin Posts: 6,314
    What happens if you try to download and install that file with DIM?
    Thank Sevrin for your suggestion .I have installed the product using DIM correctly
    Normally i don't prefer to use DIM but thi time it was a solution
