Settings gone wrong.
Could someone please help. I have a situation here where as I click on the cube my figure turns into hundreds of white lines, squares and other shapes. It's my own fault, I've been trying to improve my knowledge of DAZ3D this afternoon and have obviousle changed a setting and messed things up totally. When I un-click the cube the figure reappears. (I've attached examples). I have tried to correct this issue my self but without success. I have tried every setting from the dropdown menu next to the cube and I've had a good look through the render settings all to no avail. Maybe there is a way to re-set DAZ to it's original settings?
Thank you.
  • fastbike1fastbike1 Posts: 4,083
    You probably have a different tool selected. Use the "node Selection" tool as your default.
  • Cat_DancingCat_Dancing Posts: 535
    edited May 2020
    Thank you Fastbike1 I'll try that.Incidentally I've just tried (Window - Workspace - Customise - Defaults) but that didn't work either.
    Nope! Just tried it but no luck. Thanks for trying to help. You have a nice day.
    I feel a re-install coming on..............................hot damn!
    Surely there must be a way to re-set the defaults...........???
    Post edited by Cat_Dancing on
