IM files on C Drive filling up fast
Haruki790
Hello,
I've been told that there is no work around for this and so my 500gb ssd is around half full now,can any be safely moved or deleted without affecting content?
Thanks
You can delete the zips, but not the other files or DIM will think it needs to re-download and install everything.
However, if you click on the little cog and go to advanced settings, then click on the Downloads tab
The very first input is the drive and directory where DIM will download stuff to and install from. I have mine set to a backup drive
Ok, I see mine was still pointing to C drive, thanks for that!
Who ever told you there was no solution, was completely mistaken, There are a number of ways to fix this issue, which have been discussed frequently.
You don't need to keep the .dsx files in the downloads folder once you've installed the product.
Great, that should free up A LOT of space,thanks.
