IM files on C Drive filling up fast
Hello,
I've been told that there is no work around for this and so my 500gb ssd is around half full now,can any be safely moved or deleted without affecting content?
Thanks
  • kaotkblisskaotkbliss Posts: 2,918
    You can delete the zips, but not the other files or DIM will think it needs to re-download and install everything.
    However, if you click on the little cog and go to advanced settings, then click on the Downloads tab
    The very first input is the drive and directory where DIM will download stuff to and install from. I have mine set to a backup drive
  • Haruki790Haruki790 Posts: 59
    Ok, I see mine was still pointing to C drive, thanks for that!
  • fastbike1fastbike1 Posts: 4,081
    Who ever told you there was no solution, was completely mistaken, There are a number of ways to fix this issue, which have been discussed frequently.
  • fixmypcmikefixmypcmike Posts: 19,710
    You don't need to keep the .dsx files in the downloads folder once you've installed the product.
    edited May 2020
    Great, that should free up A LOT of space,thanks.
    Post edited by Haruki790 on
