I can't get my hair in the Iray Render window
BigMacBigMac Posts: 97
Hi,
I need your help. I can't get my hair in the Iray Render window (see picture in the attachment). I would be very happy if you helped me.
Thanks a lot
Reza from Berlin
  • scorpioscorpio Posts: 8,533
    Which version of DS are you using
  • BigMacBigMac Posts: 97
    Hi,
    I use DS 4.12.0.86.Pro Edition (64-bit) • Mac Pro, MacOS High Sierra.
    Thank you
  • RedzRedz Posts: 1,459
    It's a dForce hair, so firstly make sure you're not in the Geometry Editor tool, as dForce hair won't render if you are. If that's not the problem, look at the hair (not the cap if there is one) and in the parameters make sure viewport and render line tessellations are set to 3.
    Hi Redz,
    Thank you very much, it worked and now I can continue. By the way, I looked at your gallery, great.
    Reza from Berlin
    4902 x 2680 - 2M
    Glad you got it sorted Reza.
    Redz (from Dublin)
    Redz (from Dublin)
    Thank you very much
    Reza
