It's a dForce hair, so firstly make sure you're not in the Geometry Editor tool, as dForce hair won't render if you are. If that's not the problem, look at the hair (not the cap if there is one) and in the parameters make sure viewport and render line tessellations are set to 3.
Hi Redz,
Thank you very much, it worked and now I can continue. By the way, I looked at your gallery, great.
Reza from Berlin
Which version of DS are you using
Hi,
I use DS 4.12.0.86.Pro Edition (64-bit) • Mac Pro, MacOS High Sierra.
Thank you
Hi Redz,
Reza from Berlin
Glad you got it sorted Reza.
Redz (from Dublin)
Thank you very much
Reza
