In Iray, How Do You Change the Color of Something?
FauvistFauvist Posts: 2,291
If I remember correctly, in 3Delight, when you wanted to change the overall color of a surface, you'd go to the Surfaces Tab, and choose your surface, then click on Diffuse, and you'd get a DIFFUSE COLOR choice.  In Iray, with all those adjustments, is there one tab, or box, or something, that does what the 3Delight DIFFUSE COLOR option did?
Thanks!
