Content Wizard
I installed Content Wizard with DIM, but I can not find the menu / pane for it. It isn't listed under the Window, Panes menu. Does anyone know where to locate it or to initiate it?
It's not a menu or pane, it's a script you run from Smart Content or Content Library. Acording to the ReadMe, you should find it here:
You can find new icons for loading this product in the following DAZ Studio Folders: (THIS IS FROM THE CONTENT LIBRARY PANE)
“Scripts:RiverSoft Art:Content Wizard”
You can find new icons for this product in the following DAZ Studio Categories: (THIS IS FROM THE SMART CONTENT PANE)
“Utilities:Scripts”
Ok, Thank you. found it in the content library. I must have missed that skimming through the pdf.
