Barbarian Warrior Outfit
!green_9dd09f3341!green_9dd09f3341 Posts: 78
edited March 2020 in The Commons
Where is the template?  I bought the package and need the template.
Post edited by !green_9dd09f3341 on
  • nonesuch00nonesuch00 Posts: 18,863
    You mean the lederhosen / bundhosen? That's more like a Bavarian Worrier outfit. The Bavarian Warrior outfit I've not seen.
    If there are templates you must go to the product page via My Library in your My Account online at the daz3d.com site & download the zip & manually extract it. Templates are not delivered via DIM or DAZ Connect.
  • GordigGordig Posts: 10,759
    That's a better guess than I had. I figured that they were misremembering the name of the Sylvian Warrior.
  • Pack58Pack58 Posts: 750
    If you mean the Barbarian Warrior Outfit: https://www.daz3d.com/barbarian-warrior-outfit-for-genesis-8-female-s there doesn't seem to be one.
    You  can use https://www.daz3d.com/uv-tailor to pull up the uv's for any obj's loaded in DS otherwise there's a number of apps around that will do the same but not from within DS.
    YOu hit the nail on the head!  LOL;  there wasn't one!  I had a program for that on my big coomputer, but it's been 10 years while I took caare of Mom and I can't remember the name of it.  NOT funny.  LOL  WIll check out link.
    Thank you all.
  • OK, made a template;  now is there a tutorial somewhere to make the files for DAZ Studio to load the templates?
    Templates are decorated in an image editor. When done, save to your subfolder in textures under Runtime.
    On the Surfaces Tab, on the applicable dials add the image(s). Save out new mat files.
    Does Bavaria have a country on the map?
    i've seen pretzels of Bavaria
  • SevrinSevrin Posts: 6,314
    You don't usually hear about Bavarian warriors unless it's Oktoberfest.
    Terrific, but the template is not good so will have to find my UV prog to make a better one.  I did a lot of texturing for products years ago for Poser so hopefull it can'tbe too much different.
    Thank you!
  • it is Barbarian Warrior, not Bavarian;  sorry bout that!
  • JOdelJOdel Posts: 6,322
    Might want to change the Thread title then.
  • I looked at the video on the surface pane and it made no sense to me . . . wher can I find a step by step tutorial that isn't a video?
