Misty's G8 Fix-How do Install it?
2»
    edited March 2020
    But simply my friend and I are trying to load your figure (without any change).
    No extra requirements are needed?
     I ask because in the edited text file, I saw something that said VERONICA
    "file_version" : "0.6.0.0",
    "asset_info" : {
    "id" : "/0%20Genesis%208%20Carrara/Veronica%20Wr8th.duf",
    asset info is commented out,
    by file path, i meant when adding a ds content folder to carrara tray, the data folder needs to be at top
    content or my library,
    • data
    • people
    • runtime
    also double check you see 'people' folder and not 'daz people' folder
    Post edited by Mistara on
  • ChrisSerketChrisSerket Posts: 202
    edited March 2020
    In my previous comment I left a screenshot of how I have everything, although according to what I saw, they are the correct routes.
    It is:
    828 x 756 - 74K
    Post edited by ChrisSerket on
    hi,
    a screenie of your carrara tray of the content tab?
    did you use 'add folder' or 'add runtime' option?
    It looks like this:
    1680 x 1050 - 228K
    this one looks correct
    is there a data folder under here?
    471 x 256 - 20K
    961 x 458 - 59K
    My second directory would be the one in the photo I just attached.
    PD: What is "DOTA"?
    824 x 256 - 8K
    data
    It here:
    828 x 756 - 79K
    edited March 2020
    2nd directory in carrara tray doesnt match the folder screen shot
    sorry, but i confused nowindecision
    Me too xD
    Could you show me how Carrara looks configured in your case please?
  • StezzaStezza Posts: 9,265
    The structure should look similar to this
    click the pic for bigga
    920 x 976 - 94K
    it looks to me those directories that say runtime are poser runtimes.
    i dont use the default My Library.  my top folder is GN8 content, data is a direct subfolder
    1149 x 779 - 197K
    703 x 521 - 58K
    701 x 404 - 47K
    973 x 627 - 113K
    edited March 2020
    I understand, thank you both.
    But I have a question Misty, why does your "DATA" folder appear in another call "! GN8 content" ?.
    Is it something vital that has that name or is it something totally optional?
    I have another question.
    Is it necessary to have Genesis 3 for Carrara to use Genesis 8 for Carrara?
    I ask because I see in the images that appear the figures of Genesis 3 for Carrara.
    g3 and g8 are separate starter essentials. separate installs.
    i have multiple ds library folders.  i don't want to have to back up my entire ds library every time i add a g8 morph.  i've been here 10 years, a lot of gigabytes over the years.  lol
    where your directory says 'My Daz Library',  mine is 'G8 content', just my way of organizing.smiley
    carrara understands relative paths.  as long as data is at the top of the tree where you load the character from, carrara will find it.
    and i should mention *the preset does not have the toe morph fix built in.
    I understand
    And I know what it's like to grab Daz content especially when it's free or at a huge xD discount.
    Well, I will prove what you say.
    Thank you.
    PS: Thank you for advising about the toenail, but I already knew it because it is mentioned a lot in various xD forums.
    It still doesn't work.
    And my free trial of Carrara is about to end TT.TT
    what happens if you try to load a basic wear item from the g8 starter essentials?
    edited March 2020
    It appears like this:
    PS: If I try to boot the basic elements of genesis 8 essentials (either genesis 8 female or male), carrara just quits without throwing any errors.
    1640 x 622 - 134K
    try a clothing item from the basic wear.
    this will test if the folder is attached to the carrara tray as a daz folder.
    edited March 2020
    Genesis 8 female clothes yes do load:
    1666 x 981 - 261K
    kewl.  is the g8 carrara preset in the same runtime  as the clothes?
    Yes, everything is in the folder "MY DAZ 3D LIBRARY"
    i cant think of any other reason why the clothes will load and the preset doesn't.
    same path pretty much covers it. cool
    764 x 276 - 47K
    edited March 2020
    I do not know if this is related to the problem, but the trial version I am using is not from Carrara 8.5.1.19 but from Carrara 8.5.0.243
    I just couldn't find a trial version of Carrara 8.5.1.19
    g8 uses the udim uvs, not sure what version added support
    and is there no way to bring some genesis 8 figure by fbx or other format to carrara from daz?
    (without losing the bones or morphs)
