Is "Energy Efficient Living Room" meant to be a joke?
2»
  • memcneil70memcneil70 Posts: 6,163
    Speaking of housing does anyone know if the store has a mini home? You know sort of like a tricked out storage locker?
    There is also https://www.daz3d.com/tiny-house-and-deck and its add-on https://www.daz3d.com/tiny-house-and-deck-entertainment-props.
    Mary
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    Ascania said:
    kyoto kid said:
    ...actually the new LED bulbs which are even more efficient and don't use toxic materials.
    However must get cold in winter as well as stuffy and stifling in summer as there are no apparent means of providing climate control (no ducts or vents).
    Yep. LED bulbs seem to use about 10% less power for the same lumens. The toxicity is true too. What I don't know is the life. The 10000 hour CF lamps certainly do not last 10000 hrs. I've had a number fail less than 10000 hours after purchase, letalone having had them on for 10000 hours. I suspect the chance of getting 50000 hrs from an LED is close to nil, despite that being the life quoted for a number I have bought. I've had one fail already, after possibly 200 hrs of use.
    The LEDs themselves often have no problem lasting that long (although they will lose brightness as the phosphor degrades), it's the power supplies that blow most of the time. Or they die from poor heat management.
    I have this alarm clock that my parents gave me around 1980 that has red LED numbers.  Still going strong, although the sound quality sucks as the radio speaker cone didn't hold up so well... that'd be well over 300,000 hours on the LED's, as I've used this thing constantly in different settings as it's compact enough to put just about anywhere.  It currently gains on the time by about a minute a month, but that's easy enough to correct as needed.
    This might be a case of 'they don't build them like they used to', but it's noteworthy nonetheless.
    Anyways, as for the apartment mentioned in the OP, yeah I don't see it winning any LEED awards... as for 'traditional' attics, there ARE ways to significantly improve their 'R' values after the fact, to R38 or higher, just sayin...
    Vaulted ceilings are OK, IF they are properly insulated.  But I'm not seeing any insulation between those ceiling joists.  They are visually more interesting than a flat ceiling of course...
    I get that PA's like using interesting titles to get people to look at their product though.  That's how the game is played.
  • dragotxdragotx Posts: 1,149
    Noah LGP said:
    The Citadel... doesn't look like a citadel. Many product names don't reflect the content.
    No, but it does closely resembe a section of a space station called the Citadel from a major video game series.
    It does,and that place was in at least two of the games, as I recall.
  • AscaniaAscania Posts: 1,856
    You're right about them not building like they used to. Those LEDs used a completely different chemistry to modern high brightness ones.
  • Speaking of housing does anyone know if the store has a mini home? You know sort of like a tricked out storage locker?
    Mary
    Outstanding thank you Mary!
