Genesis 8 female won't load or won't correctly load
I was using a Genesis 3 converter to Genesis 8 which is from the Daz store and since then I can't get Genesis 8 female to load.  If it does come in it doesn't load correctly.  I tried unstalling the Genesis character I was wanting to load and then re-installing it. I tried to uninstall the Genesis 8 female starter.  I also tried using another Genesis 3 to Genesis 8 converter.  Attached are the images from the error message and what it loads incorrectly.
Becky
  • AeonmoonAeonmoon Posts: 53
    edited February 2020
    Might be a different issue, but whenever I have a base character not loading properly it is generally fixed by the Restore Figure menu, found here:
    [Edit] -> [Figure] -> [Restore] -> [Restore figure].
    I suspect that for some reason your G8F have become reconfigured and the new configuration might be overriding the reinstalled files.
    Could be something entirely different but it's worth a shot.
    From the error message I'm thinking that perhaps the files that the program consider duplicates have been installed in a location which isn't recognized by the uninstaller.
    Post edited by Aeonmoon on
  • BHawkBHawk Posts: 61
    Thank you for your reply!
    Most of the time when I try to load Genesis 8 female, Daz Studio closes. But I did get a figure to load and "restore figure" didn't work. I tried it twice and nothing seemed to of changed.  I thought maybe if I posed it, but that shut Daz Studio.
