Genesis 8 female won't load or won't correctly load
BHawk
I was using a Genesis 3 converter to Genesis 8 which is from the Daz store and since then I can't get Genesis 8 female to load. If it does come in it doesn't load correctly. I tried unstalling the Genesis character I was wanting to load and then re-installing it. I tried to uninstall the Genesis 8 female starter. I also tried using another Genesis 3 to Genesis 8 converter. Attached are the images from the error message and what it loads incorrectly.
Becky
1123 x 597 - 302K
Might be a different issue, but whenever I have a base character not loading properly it is generally fixed by the Restore Figure menu, found here:
[Edit] -> [Figure] -> [Restore] -> [Restore figure].
I suspect that for some reason your G8F have become reconfigured and the new configuration might be overriding the reinstalled files.
Could be something entirely different but it's worth a shot.
From the error message I'm thinking that perhaps the files that the program consider duplicates have been installed in a location which isn't recognized by the uninstaller.
Thank you for your reply!
Most of the time when I try to load Genesis 8 female, Daz Studio closes. But I did get a figure to load and "restore figure" didn't work. I tried it twice and nothing seemed to of changed. I thought maybe if I posed it, but that shut Daz Studio.
