Adding to Cart…
This product messed up all my G8... It takes forever to load and it generates lots of errors... Older scenes cannot be loaded, they take 30 min to load and do not load at all. Sorry, I needed to uninstall!
A quick example of a custom character. I set her to subD 3, switched on thecdkin details and applied one of the presets and tweaked the settings. The expression is one of the predefined one. It takes longer to render but impressed by the results.
Please read the old posts to get AFE going again. Daz is looking for the Old files so it is killing time. Please remove all he AFE and reinstall. You have to delete the old AFE wearable and put on the new one and resave the AFE. It is a new different geometry and the new HD morphs are not build for the old AFE.
It is in Sub-D so rendering will be heavier. Remember lighting raytracing shadow will add better details on the skin too.
Impressive!!!
Did a test run on Auto Face Enhancer today? I really like how the details you can get working + go with real-time rendering on Marmoset. Sub_D 3 on obj export.
I will fix the HD detail causing the ears to overlap when adding details morphs. sometime this week and put it here and for an update to DIM.
This is a second test example. Same character and AFE settings but this time using one of the portrait lighting rigs from Ultra Genesis Studio Iray box lights. This shows the skin details a little better.
I have a new update for "AFE - Reak Female HD Expressions for G8F" size 245.5MB is it safe to update? Any experiences?
i'd love to know too. is this the updater that's going to install everything where it needs to go?
This update will have the HD smoothing to the Expression.
With DIM install now it will be easier to uninstall without going into the AFE folders.
The Dropbox update is no longer needed.
Which character is Marmoset? I tried to find him in the DAZ Store. I he sold here?
Marmoset is the company that developed Toolbag, a realtime renderer. He exported the DAZ model to it and rendered it there.
https://marmoset.co/posts/creating-realistic-skin-toolbag-saurabh-jethani/
I will put the character up for sale in a few weeks. Working on the texture now.
The character looks terrific. I'm so impressed.
FYI, new AFE Update from DIM causes Studio to throw a Missing File message for it, even on scenes where it is not used.
I ended up with the duplicate formula problem. Uninstall didn't really work so had to manually uninstall. Got that all cleared. Reinstalled with DIM and that cleared the errors but....now when I try to load the AFE geometry....
First it asks if I want to save scene before loading
Then it gives me a 'file does not exist' error.
I've checked my directories and it's installed there.
Any ideas? I really depend on AFE to tweak my expressions
So when I make this procedure am I still able to play around with various morphs and adjust the shape of my figure afterward or when I adjust anything do I need to do all of that again?
If the latter then that would be rather inconvenient because when I make significant changes I always need to redo the Zbrush stuff?
Thanks for answering, really looking forward to test this out :)
EDIT:
Btw. the update worked flawlessly on my machine. However, I made sure to first uninstall the old AFE file using DIM and installing the new AFE file afterwards also using DIM.
How to remove the stripes on the surface? Is that a bug?
That's what we have to fix with the above mentioned 13 steps. The author cannot adjust his product for all of the different characters out there. Currently trying to figure this stuff out. Also watch the video tutorial that Mart1n71 provided very kindly.
EDIT: OMG I did it. I am so happy and proud of myself. This was super difficult because I had only a very small (basically none ZBrush) experience. Thanks again for the tutorial @Mart1n71
But also I am realizing that I need to adjust the AFE Mask each time I modify my character. So the workflow will be finalizing my character and creating the corrected AFE morph afterwards.
You need to apply this to your G8F. It's not applied on the screenshot you provided. Won't work without it:
you need this
https://www.daz3d.com/auto-face-enhancer-hd-with-powerpose-for-genesis-8-males
you may like to have this
https://www.daz3d.com/afe--real-male-hd-expressions-for-genesis-8-males
what character ? do all characters the same. if yes then please uninstall and reinstall. We do have a new update.
Not all characters are cover by AFE.
looks like
Grace Yong Smooth fix. please look at the Zip file and put this in your AFE library data folder.
QUOTE
ZIP
But this smooth fix is only for the G8 females, right? Or should it be used for the G8 males as well?
what is happening is Daz cannot find the file or because it has 2 files and it won't know what to do with 2.
Uninstall everything. Do DIM uninstall first to remove those DIM link. Then Un-Install manually by removing all directory.
1-You can check by downloading all the installation files. open the zip to see the directories.
2-Create an AFE directory and put all installation files in to here. Add this to your Daz library folder. Close Daz3d
3 now open Daz3d. Daz will load up all directory. From AFE directory you should be able to load the AFE. This works because it is loading the AFE from a clean directory.
I believe you will have to re-do the smoothing for any significant change to the G8F geometry. Small changes you may get away with not noticing.
Correct. HD is very demanding. FYI = You can hide some of the imperfections with the Skin details.
this smoother is only for this character.
AFE has many characters smoother on. It does not cover all characters...only the many many I have put on.
Yes, seems like that is an unfortunate limitation. However, Mart1n71, you were very,. very kind in putting together a tutorial so you can use any custom character. Thank you again!
so if i get this right, not all morphs are supported by AFE? And you have to create your own smoothers for them?
Is there perhaps a way to automate the creation of smoothers using a script?
