Missing
Has anyone had these issues in michea 4 internal organs I have installed via install manager yet it seems that its missing certain atributes On a mac 10.14.5 Mojave
Many Thanks
Many Thanks
That is just a missing thumbnail - if the file itself was missing there would be another warning icon at bottom left.
trouble is i get thuis aswell its all installed via the install manager
Click back in the Smart Content pane, so you see the lst of products instead of the fles within the product. Does the product's thumbnail have a downward triangle in a circle at top-right?
This is what i have got it seems everything is not what it seems i should have the Micheal puopet as well just wondring do i need to upgrade the system softaware as i have Mojava at present
any ideas its just not finding the files
Many thanks
I have installed so many times wondering if i can do it manually but i need to know the correct directory
The database thinks there is a Connect install for that, which is why it desn't have the circled triangle icon. Right-click on the product in that view and select Uninstall, see if if it will then pck up the files placed by Install Manager.
no still having problems micheal internal i cant trun the organs off yet its in the smae directory as the rest it seems the whole direct if misguided or files are not working wonder if there is a pc or mac issue as there exe files there as well
You are using them with Michael 4, or on their own, rather than converted to another fgure?
Micheal 4 as i have his organs and skeleton
I wonder if its a copywrite issue as i had a coupke of emails that need to merge int one I clutching on straws here
Try dragging from the content pane onto the fgure in the scene.
Thank You bizzarly that works ish
Now the problem with the function of the of the internal organs all the files are there in the same folder but does not show in the menu any ideas
That is a Connect install, not a DIM install. Is the My Daz Connect Library currently set as a Daz Studio Format Content or Daz Connect Data Directory?
