LAMH update 1.5
AdemnusAdemnus Posts: 744
I own LAMH, but I see no update to the new version in my DIM. Any hints?
«1
  • BeeMKayBeeMKay Posts: 7,019
    That's my question, too.
    Do we have to buy an upgrade (if yes, what would be the link to that product page?), or download the updateelsewhere?
  • Alessandro MastronardiAlessandro Mastronardi Posts: 2,665
    No, the 1.5 is a free update. Probably DAZ servers didn't sync yet, but it will available in your DIM.
  • Pixel8tedPixel8ted Posts: 613
    edited January 2014
    I manually downloaded the new installer from my DAZ product library this a.m. so it's there even if it isn't in the DIM yet.
    Post edited by Pixel8ted on
  • gabugabu Posts: 303
    The product page mentions minimum Windows specs of an openGL 2.0 capable graphics card
    does this mean that with a lower speced card LAMH will just not work at all or just that its performance will be slower or something?
    Difficult to predict what may happen with a lower spec card. Which one do you have? Maybe we tested it and I could give you some information.
  • JabbaJabba Posts: 1,466
    My updated installed through DIM this morning without any issues
  • Richard HaseltineRichard Haseltine Posts: 111,996
    I see LaMH in DIM too, though it doesn't say 1.5 in the file name (presumably so that DIM knows it's an update of the older version)..
    I had been worried because the installation is a bit complicated - I am running Studio on Win 7 in a Virtualbox machine on a Linux host.
    Studio reports the openGL version as: 2.1 Chromium 1.9
    Am I OK? Presumably the 2.1 is the crucial number, I don't know what the 1.9 means.
  • Kendall SearsKendall Sears Posts: 2,995
    I haven't tested LAMH in VirtualBox environment in a while. I don't see why there would be a problem though. I'll load up a VBox session a little later and try it myself just to make sure.
    Kendall
    thanks in advance for making the effort
  • SimonJMSimonJM Posts: 6,108
    It caught me on the hop by appearing within DIM in the Product list, not in the Product Updates list - I could have sworn I had obtained (a version of) LAMH via DIM. Maybe it was 'just' the Player that I did.
  • IndigoJansonIndigoJanson Posts: 1,100
    I'm feeling stupid. I did the 64-bit download via the DIM and it appears in the Installed pane of DIM, but if I select Installed Files the box is blank.
    I can open LAMH from Studio but once I've re-entered my details I end up in the 1.01 version.
    Is there something I've missed? Do I also need the 32-bit version for all this to work? Should I have uninstalled the older version?
    Probably the easiest thing to do would be to uninstall, then make sure that there are no dll files starting with lamh in your DAZStudio4 plugins folder (if so, delete them), then reinstall from the DIM.
    Kendall
  • IvyIvy Posts: 7,165
    edited January 2014
    I just bought LAMH along with the new moose.
    the moose works great.
    Look at my hair program not so much.
    so I don't know what I may have done wrong so I'll try to add snipits to my post.
    Image 1- daz recognize my LAMH plugin automatically with out asking for my Serial Number, is that suppose to do that?
    Image 2 I had to manually load look at my hair from my program folder. it did not load a start menu on my desk top or my start menu as I had set during install
    I also had to save my project before i could get it to load into the LAMH program - Is that suppose to do that?
    Image 3- The follicles box does not not look the same as the way you have it in the pdf instructions . it does not list the tabs as on or off.
    Image 4 The Grow hair sliders does not work or seem to be frozen in place, when I try to move them but they just return back to the original setting and the hair follicles don;t react to the sliders. I folowed thwe PDF instuctions but this does not seemt o resolve the issues.
    Other than that I can't tell you any more because it appears at least for me that I can not get this to work in Daz Studio Pro4.6 64 byte version, and that is as far as I can get with this plugin
    Is LAMH supported in Dazpro4.6? I have followed every instruction you had in the provided PDF and I still seem to have a frozen version of LAMH
    Also none of the Desk Top Icons or start up menu icons or the Uninstaller - installed even with default settings checked
    Any Ideas on how I can fix these issues . I hate to return this product, I had it in my wish list a long time and used my bonus commission money to buy it. so any help would be great... or is it not supported in Daz4.6?
    I should add my computer more than well fits into your system requirements I added a snap of my graphic card gpu :)
    Thanks ~Ivy
    601 x 621 - 39K
    1558 x 1143 - 134K
    1604 x 1160 - 130K
    1502 x 871 - 135K
    704 x 872 - 54K
    Post edited by Ivy on
    Kendall
    Thanks for such a quick answer, Kendall. I'll give it a go. Fingers crossed.
    Hello Ivy, the 1.5 documentation is still being worked: we hope to have it released this week.
    However, the reason why you can't use any slider is that you actually didn't grow any guides. See attached image showing the button to be pressed for growing hairs.
    1604 x 1160 - 269K
    edited January 2014
    Thank you very much for the quick reply
    and thank you for resolveling my hair growing issue. i knew I was doing something wrong somewhere.
    I look forward to a update in documentation, because that will be most helpful for a blond like me fer-sure
    Very well Ivy: I'll try to have the documentation ready asap.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,816
    was optimistic as it synced in playback but unfortunately rendering an animation it cannot quite tween
    still nearer than before though!
    1920 x 1080 - 7M
    Animation support should come in next update.
    Having downloaded LAMH via DIM a day or so back I was a little surprised to see it 'back' as a Product Update already! Dare I ask what was changed?
    We fixed a crash that slipped through the cracks. If you've downloaded the previous version, please update to the current DIM version ASAP.
    Kendall
    Kendall
    Ahh, can't really complain about that, eh? :)
    animation would be soooo cool!!
    See a LAMH animation here: http://youtu.be/BTXYE43IKQU
    Kendall
  • swordkensiaswordkensia Posts: 348
    edited January 2014
    Kendall
    I have been updating LAMH via the Release Candidates...If I download and install the latest 1.5 LAMH Full from my Daz library and install it, will I have to go through the registration process again or are the orginal Registration details maintained.
    Cheers,
    S.K.
    Post edited by swordkensia on
    Hi, you shouldn't have any need to reauthorize.
    Thank you Sir..!!!
    Brilliant update and additions by the way...
    Regards,
    S.K.
    Thank you Sir..!!!
    Regards,
    S.K.
    LAMH is only going to get better. MUCH better. :-)
    Kendall
  • TJohnTJohn Posts: 11,448
    Kendall
    Cheers,
    S.K.
    I had this question as well and would like to know if I need to delete any of the previous RC, or will the new release simply replace it?
