Adding to Cart…
I can't believe that I somehow missed the release of this product and only just saw it today. I found this thread because my only question was about what happens to an object outside the camera that is used to create instances. First post of this thread includes the manual and I found the answer to my question in less than a minute.
On the basis of being able to read the manual to help me make a decision, this product is going into my cart to buy right now. I'm looking forward to doing some testing on some of my bigger scenes.
Thank you for your kind words and support
Excellent concept, documentation, and implementation. Your extreme anal retention is so admirable. Your previous employers must love you (or be threatened by you). Hopefully, you don't require that your family members live up to your own standards. Keep up the great work (as if you have a choice).
I strongly believe in doing something that gives one good value for their money because that's what I would want from a product.
Cheers
I did try it again.
I just want that the script hide the bodyparts under the blanket, so i save Renderpower/time.
The body parts of the sitting man did I already hide.
And... why the heck is the script always bringing BACK the big thing I just used for the Dformer? -_-... I thought its job is it to HIDE.... *sigh*....
I dont wanna delete it, and... yeah thats all what the script does, it unhide my object :/
so... what is "is DzBone" why does he ignore it?
Uh, I will take a look at it, when i open the scene again, but atm... I hate to work at the set... it takes just too long... my PC can not really handle the room, it have 4.000x4.000textures on all objects thats just an overkill -_-
As I explained earlier here, this behaviour will change in the next release. There will be an option for the tool to ignore hidden nodes.
Nodes of type DzBone are the body parts (bone nodes) of the figure, like the hip, pelvis, abdomen lower etc. Although they are valid nodes, the tool ignores them as it does not hide (at present) individual body parts, only props and full figures. I plan to change this behaviour in an upcoming version.
I suggest you use this tool to reduce the size of your textures and make your life easier.
Hope this helps
Hi, I am using daz studio 4.10 and would like the patch.
Check your PM. I've sent you a link on the 26th January with the patch. (Right after you messaged me)
Thank you don't check that too often. Downloaded and installed. Nice plugin
You're welcome
I still wanna try the tool, but... it say nope ;(
See attachment, I wanna make a Scene from the House entrance, but the tool doesnt want to hide all the stuff in the background.
The fences, the stairs inside, the walls and doors in the house, that all should be hidden.
Do I use it wrong?
I made it now all by hand, see image 2. I don't understand why the script not does it ;(
What you want hidden, is actually visible in the viewport. The script will (attempt) to hide items not visible in the viewport.
that is what I want...
but it does not hide anything.
I found now the problem, "bones" objects and Parents of a group dont get hidden by the script, thats sad...
The black cube get not hidden, because its the parent.
And here it does not get hidden, because its "bones" of a object.
Thats... weird, so i have to hide it all by hand.
You still don't seem to understand. If part of a prop extends into the viewport, the portion outside of the viewport can't be hidden / eliminated. The script can't modify individual props.
After some initial testing of this product right after buying, I was busy with work for a while and just got back to having some time for rendering.
Absolutely loving this product. I've just used it with the Ultratrees product in a scene with two of the ultratrees. It made a huge difference to the size of the scene by stripping out thousands of unseen leaves.
Loved that scene you posted in the gallery.
Thank you very much. Your product helped a great deal in fitting the scene into GPU memory. Fantastic product, worth every penny.
I'm using 4.11.0.383 and I am having the same problem as many others. Please send the patch.
Thanks,
Alex.
I've sent you a PM.
Please check your inbox.
Thanks
Is there a way to exclude items that are emissives? I've caused myself problems by not triple checking what's hidden and what's not.
Unfortunatly not in this version. You can only exclude using partial or exact matches of node names.
This feature has been asked for before and will be taken into consideration in the upcoming version.
Hi ;) I'm using daz studio 4.10 and i would like the patch please
thx
I've sent you a PM.
Thanks
thank you ;)
@Callidus Simia, I'm using 4.12. If I install Camera View Optimizer today, will I need the patch?
Okay... I just purchased this product, and I must say it is a Godsend. Wow! I'm typically a one-and-done type of renderer, so I'm not really worried about stuff being deleted. Even if I was, I'd just save the file first, then close it w/o replacing it. Camera View Optimizer literally stripped thousands of unseen things in my scene, saving valuable render time. There was no way I was going to go through that set, trying to figure out which things to delete, etc. Thank you, @Callidus Simia!
Thank you for the kind words :)
I can see that this would be very useful indeed—for still-image renders. I read through the manual you thoughtfully provided, and through this thread, and apparently (?) this script does not work dynamically with an animated camera, in which the camera's motion moves to show different parts of the scene.
Is that right? If so, it would seem to make sense that this should be stated expressly in the marketing and in the manual.
You are correct in your conclussion that this tool can only be used for still image renders. This current version (which at the time of writing is 1.0.2) is not designed to work with animated cameras and this is a feature might be coded in a future version as a possible addon.
As you rightly point out, there is no mention of animated cameras in this thread, nor is there any mention in the accompanying manual and that is because I initially thought that there was no need to state that fact. However, I think that your point does makes sense, and I will add a disclaimer at the bottom of the description of the product in this thread.
Changing the marketing wording in the store together with the accompanying manual to add the one line is a longer process that usually takes weeks, so that will be done when I'm ready to push out an update that will fix a few minor bugs which have been nagging me.
Stay safe
K.
