2020 "There's Always Another Sale™" (Report sales errors here.)
Adding to Cart…
And you're not getting 4.97 on that? That's what your one image showed, yes?
Edit: OOps, i see, it was $6 something. Do you have the requesite addons and purple banner?
Yes, I'm getting 6.75 on it.
Edit:
And yes, I have the products in my cart.
For the other categories I am getting the 30 off. This is the only one not working properly.
Ok, so if you have the pro bundle plus 3 addons and the purple banner, the only thing you can do at this point is a ticket, I'm afraid.
Cris, could you please tell the web people that the $2.20 sale does not show up at all in the current iOS 13.3 for iPad and iPhone. Apparently it does work for a larger screen iPad that can use a different iPad iOS, but not for regular iPads and iPhones. Thanks.
Turns out I was remembering wrong. Yep, the Dain 8 prices were higher than I remember. And not consistent with the discount being offered.
The fact that Leroy 8 + 2 addons costs less than Leroy 8 + 3 addons tells me I'm on the right track with the discount math though...
Doing the math: For 2 items: 15% off pro bundle + addons, purple banner additional 30% off pro bundle + addons: Total price:
134.95 *7 (new item) * .7 (Daz original) * .85 (15% off) * .7 (30% off purple banner) = $39.3446725, which almost exactly matches the price shown in cart above.
Sooo, if the math works this way for 2 items, it should work the SAME way for 3 items, which is
134.95 *7 (new item) * .7 (Daz original) * .8 (20% off) * .6 (40% off purple banner) = $31.74024, which is NOT anywhere near the amount shown in the cart below:
Note that this same math applies to the addon items as well, same discounts, and that the price jumps up a bit when you add a third addon item to the cart.
Just consolidating this into a single post for completeness purposes, and to illustrate the fact that the discounts aren't being applied the same way for each instance. The second cart is applying a 40% discount only, not including the other 20%, while the first cart is applying both additional discounts.
See attachment for a screenshot of the purple banner I received, note that additional discount only has a single asterick...
Note that in both cases, the additional discount has a single asterick, not a double asterick. The double asterick 'does not stack' language only applies to the $30 in addons part. Since the 30% off is being applied additionally with two addon items, this tells me that 3 addon items should similarly get 40% off additionally.
I'll be submitting a ticket for Dain 8 after the fact, as this language matches the Dain 8 language as I remember, if I'm recalling correctly. As for Leroy 8, haven't finished putting my cart together yet...
Problem is i just checked my iPad and this is what I see. I'm on a pro. I can ask the web team to check, though.
tj_1ca9500b, please screenshot your bundle product page and show me the price you start with please.
It's the 'usual' $66.13, 51% off Chris. See attached.
So 39.68 is the correct price. Whatever the addon price on the product page should be 40% off that. Is that not what you're getting?
If you look at the screenshots more closely, the discounts are lower with 3 add-ons than with 2 of them, which is obviously not correct.
I see the same, btw: the discount on the various items is higher with 2 add-ons than with 3 of them.
k, let me check that out.
The addons seem to get the correct 40% off when you have 3 addons, but is getting higher than 30% when you have two. I will report this. But the three are getting the right price.
The discounts you are seeing is correct. Remember that the banner doubles the discounts, it does not supplement them.
That means the 40% REPLACES the 20%, so the prices you are seeing are valid.
This is correct.
That's not what the coupon says though. It's an EXTRA 40% off, in addition to what's being offered in the sale, which as I've shown is what's happening with 2 addons. In past sales, this is how EXTRA discounts have been applied to other additional discounts.
Otherwise, we wouldn't have had a number of people getting massive discounts on gift cards this past weekend...
if Daz's intent was to apply only 40% additional off total, instead of 20% additional plus 40% EXTRA off, the coupon should note 'replaces 20% additional discount', which is language we've seen before, even on this coupon for the 'select' items, but that's not the case here. Note that ONLY the $30 in select items has the double asterick language in play, which says 'replaces the $5/$10/$15 discount'. The offer for 2 items was indeed functioning as the coupon language would indicate.
Not trying to belabor the point here, but the language is important. We do appreciate your efforts in getting to the bottom of these things, Chris!
Same for me, Bigger discount by a few cents with 2 addons instead of 3 addons with the purple banner.
Also is there a page for the 2.20 items?
Is there a way to get the $2.20 sale items on a page intstead of the side-scroll thingy?
The banner says "additional 40%", the "replaces current offer" part is for the free items.
And that doesn't explain why the discount is bigger with 2 items.
The lack of a page for the $2.20 items is annoying - if I sort the store by price low-high I see 91 89 items at $2.20 that I don't own. The scrolling thing shows me only 25 items including ones that I do own.
Edit: 2 of the 91 are $2.20 for everyone (had to go to an incognito browser page to spot those)
Old Manhattan Apartment has no download links in Product Library and isn't showing in DIMM
Ignore this - I just realised that 69 of those are from the Stonemason sale page
Reported.
Turn off that banner ad and see what happens. Note that Cris does not have the banner ad.
Is there a page link for the $2.20 items?
No, unfortunately it's a scrolling banner.
Fixed
Has anyone got DOS-BIEN to work? Trying to purchase two really old DAZ Original texture packs for clothes but getting code invalid (PC-FOUR worked fine).
Worked for me, what I bought was two Redz Studio products that were already on sale. Figured ~$7 was not going to break the credit card balance, even if it lands on this month's statement instead of next.
Doesn't work for me either, but I did use the pc-four coupon. Maybe it's one or the other?
I haven't used either one yet and DOS-BIEN is not working for me. So far all the people repoting it not working are PC members and the person who got it to work is not a PC member. So, maybe it is only for non-PC mammbers; but it doesn't say so.
