sub D level
Philippi_Child
I was wondering how to adjust the Sub D levels in DS? Where would I find this setting?
Thanks
Philippi_Child
Thanks
It's under the General properties (undr Mesh Resolution) in the Parameters tab, but only if the selected item is (or has been converted to0 SubD (Edit> Objetc> Geometry> Convert to SubD ..). If all has been setup you will have a few options:: Resolution Level )options of Base or High Resolution)./ You will also have two, direct, SubD options (via slider): View SubD Level (which only affects what you see in the viewport and will increase memory usage dramatically all the time!), and Render SubD Level (Minimum) which 'delays' the imposing of the SubD levl until the render actualy starts, which keeps the memory usage low whilst setting stuff up, but uses it when the render happens.
Copy that thanks!
