Santa Slayer materials and instructions missing. [Solved]
lukon100lukon100 Posts: 849
It was a freebie. But when I load it, the materials are missing. And when I click on the icon for the special instructions, it says the link is bad.
Post edited by lukon100 on
  • Moved to Techncial Help as it's a question, not a Product Suggestion.
    Was this a Daz freebie or one from elsewhere? Is it stand-alone or does it require another product, and if it does do you have the other product?
  • lukon100lukon100 Posts: 849
    I cannot find the product in the general catalog. But there is a doc page for it:
    http://docs.daz3d.com/doku.php/public/read_me/index/65781/start
  • LindseyLindsey Posts: 2,015
    I just installed the product with DAZ Connect and it loaded the textures.  Maybe uninstall/reinstall?
    re: Special Instructions, it's on the Tool Tip icon.  Just hover over the "MM 00 Instructions" icon and you'll see it on the Tool Tip icon.
    1462 x 898 - 412K
    Thanks, Lindsey.
    Yes. The Install Manager had failed to install everything. But I only discovered this by uninstalling and using the Content Manager installer to re-install it, whereupon I discovered a new icon that was missing before - the icon that simply says "Laser Cannon". Using that icon to load the model fetched all the materials that were missing before when I was using the "MM 01 SS Wearable Female" icon to load the model in.
    And thanks for showing me how those special instructions are supposed to be accessed.
