Santa Slayer materials and instructions missing. [Solved]
lukon100
It was a freebie. But when I load it, the materials are missing. And when I click on the icon for the special instructions, it says the link is bad.
Post edited by lukon100 on
Moved to Techncial Help as it's a question, not a Product Suggestion.
Was this a Daz freebie or one from elsewhere? Is it stand-alone or does it require another product, and if it does do you have the other product?
I cannot find the product in the general catalog. But there is a doc page for it:
http://docs.daz3d.com/doku.php/public/read_me/index/65781/start
I just installed the product with DAZ Connect and it loaded the textures. Maybe uninstall/reinstall?
re: Special Instructions, it's on the Tool Tip icon. Just hover over the "MM 00 Instructions" icon and you'll see it on the Tool Tip icon.
Thanks, Lindsey.
Yes. The Install Manager had failed to install everything. But I only discovered this by uninstalling and using the Content Manager installer to re-install it, whereupon I discovered a new icon that was missing before - the icon that simply says "Laser Cannon". Using that icon to load the model fetched all the materials that were missing before when I was using the "MM 01 SS Wearable Female" icon to load the model in.
And thanks for showing me how those special instructions are supposed to be accessed.
