Turn off Yellow hilight on selected item in DAZ 4.6?
FirstBastionFirstBastion Posts: 8,055
edited January 2014 in Daz Studio Discussion
simple question, is there a way to turn off Yellow high light on selected item in DAZ 4.6?
  • SzarkSzark Posts: 10,634
    edited January 2014
    Yes
    Select the desired tool
    open the Tool Settings pane
    Draw Style set to Bounding Box only
    Post edited by Szark on
  • XoechZXoechZ Posts: 1,102
    If I remember correctly, you can also turn down the opiacity of that bounding box. At 0% it is not visibly any more, if you like it that way.
    edited January 2014
    I'd like it better, if it wasn't such a 'make your eyes bleed' color...can THAT be changed?
    Also, if you do go to 'Bounding Box Only'...you may need to UP the opacity.
    Post edited by mjc1016 on
    edited January 2014
    Yes Windows > Style > Customise Colors > Accent Color >
    But changing this also changes the color for the whole UI highlights
  • FirstBastionFirstBastion Posts: 8,055
    Thank you, exactly what I needed. It was extremely hard on my eyes.
    Yeah it was the first thing I turned off when installing DS4.6
