Turn off Yellow hilight on selected item in DAZ 4.6?
FirstBastion
simple question, is there a way to turn off Yellow high light on selected item in DAZ 4.6?
Yes
Select the desired tool
open the Tool Settings pane
Draw Style set to Bounding Box only
If I remember correctly, you can also turn down the opiacity of that bounding box. At 0% it is not visibly any more, if you like it that way.
I'd like it better, if it wasn't such a 'make your eyes bleed' color...can THAT be changed?
Also, if you do go to 'Bounding Box Only'...you may need to UP the opacity.
Yes Windows > Style > Customise Colors > Accent Color >
But changing this also changes the color for the whole UI highlights
Thank you, exactly what I needed. It was extremely hard on my eyes.
Yeah it was the first thing I turned off when installing DS4.6
