DS crashed when I load Noggin's Poser Crows
Hi, I used Noggin's Poser Crows often with DS previous versions. If I load the base figure now, DS crashes immediately. There is no problem with the second figure. To fix it I have deinstalled it and I reinstalled it but the problem persists.
I would be very thankful for any help
If the figure has native Poser IK chains then this may well be a crash issue that was found in the release, involving mostly older figures. If so it should be fixed in a forthcoming version http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_12_1_16
Hello
I just recently purchased the Noggin's Poser Crows also. I am having the same exact issue as above.
As I said, it is fixed in DS 4.12.1.16 or later - so it should be OK in the current Public Build https://www.daz3d.com/daz-studio-beta
Hmmm. I've had a couple of the Noggins birds for years & tried to open a couple tonight & crashes DS 4.12.086 64-bit. Will snage the beta & see if that resolves.
