HD Masculine Upper Body Morphs for G8F
I do a lot of monster and cross-gender kitbashes, and it'd be super helpful to have have a morph pack with masculine upper body shapes for G8F, ideally HD.
Right now I'm using the available cross gender morph solutions, but I haven't found a way to cross-morph only the upper torso of a G8F figure. Leaving the waist down as G8F default would make it easier to use lower body attachments like RawArt's Medusa Maker, because G8M's built-in crotch bulge tends to create distortion (and dialing it away with other morphs just causes a different distortion).
I have a few flat chest morphs, but because they don't add any masculine shape definition there it's hard to get them to look right.
This would almost certainly be a niche product, but I figured it's worth throwing it out there! laugh
  • GordigGordig Posts: 10,779
    Have you tried Body Mixer? It splits the base body morphs into upper and lower body dials.
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Does this work with HD morphs? usually these types of products don't which is why specific HD morphs for upper and lower would still; be needed
  • plasma_ringplasma_ring Posts: 1,027
    Yep! But I can't dial in male morphs to G8F and have the character look masculine without also dialing in the full-body G8M clone (or something similar, like agentunawares' transgender morph or Cross Figure). If there's a way to split that clone shape that would be helpful, but I've even tried with Shape Splitter/X-Morphs. It'll save the morph as a partial, but not the body shape that supports it.
    I can probably do something that involves taking the body shape I want to Blender and using it as a reference to sculpt a top half morph, but I'm very intimidated by modeling programs and would rather pay someone who knows what they're doing if possible. laugh
  • CGI3DMCGI3DM Posts: 281
    edited January 2020
    One step is missing, once you have the morph (any morph male + Clone), you must perform the spawnmorph in Shape Splitter/X-morphs, this generates a morph that you can use to divide it as you wish.
    Here I include a morph of a werewolf, which by means of the transfer utility, a morph was created in Genesis Female 8 (JPC_plague_wolf).
    Then I set 100% of the CloneGenesis8Male clone(hidden), so that it is identical to the Genesis Male8 morph.
    I run Shape Splitter/X-Morphs and create a new morph of the current figure using SpawnMorph.(save as Wolfman8Male)
    Now to divide the morphs.
    For the top of the WolfMan (WolfMan8Male-Legs-Remaining), save it as WolfManBodyUP
    As I will use negative morphs to preserve the detail of Mabel use (Mabel 8 Body-Legs-Remaining) save it as MabelBodyUP
    And finally apply the morphs, WolfManBodyUP (100%) and MabelBodyUP (-100%), Mabel 8 Body (100%), Mabel 8 Body HD Details (100%), Mabel 8 Head (0%)
    The upper part corresponds to the male part of the werewolf of Genesis Male 8 and the legs correspond to the female figure of Mabel.
    Note: And it can also be done in reverse, transfer the morph of a female figure to Genesis Male, and thus preserve the HD detail of the werewolf in male character.
    629 x 692 - 55K
    626 x 514 - 103K
    1860 x 885 - 258K
    387 x 288 - 30K
    775 x 888 - 67K
    Post edited by CGI3DM on
    Oh wow, I missed the update to this thread. Thank you so much for taking the time to explain this, i can't wait to try it out!
