Cutout Opacity
I want to put a logo on a surface (a tire) and the cutout opacity don't work as I wish. The pattern is repeated. The logo and the tire are two separate surfaces, not diffuse overlay or L.I.E. Does anyone know how to fix it? Thank you for your answers.
  • FenixPhoenixFenixPhoenix Posts: 3,243
    The cutout opacity mask should be all black with what you want visible masked in white. Is that how you have set it up?
  • That isn't an opacity issue, it's that the surfces iss et to tile - you need to use an Iray Decal node to project the logo, or you need a map with the logo correctly placed on the UVs for the part you are applying it to.
  • abiflashabiflash Posts: 108
    Yes, of course. I think the problem is created by being a circular surface.
    Or you could also give your textured logo a bit more breathing room or padding (empty space around it). That way the tiling won't show.
    Thank you, Richard. Iray Decal node has been useful to me.
