Render fail question
When I try to render this scene it begins normaly runs about a minute then just stops as thogh it is finished and leave a blank or all black result. I have rendered the same scene with diffent poses. I have included a screen grab of the settings, the render running and the result. I also included one of the scene that worked. I have ot shown the actual scene due to mature content.
  • FenixPhoenixFenixPhoenix Posts: 3,200
    edited January 2020
    Try moving your camera forward. Usually that happens when the camera ends up inside an object (usually a wall).
    Post edited by FenixPhoenix on
  • Try moving your camera forward. Usually that happens when the camera ends up inside an object (usually a wall).
    That is probably right but I have messed something up with the cameras. Ande I don't know how to work them. Looks like my best bet is to start over.
  • Cameras are just like any other object in a scene. You can select a camera as your viewport POV and move it around just like you would change your view location normally. When you have your camera inside a wall but you can still see the scene normally you just move the camera forward a little, I use the X, Y, Z translation sliders to move very fractionally.
  • I don't know what I did, but I looked at the camera pov and made sure it hasmy image but I still get a black render. Is there a way that it could render a camera that is not the same as the camera pov?
    Sure. Add another camera. But as I've tried to explain for whatever reason the viewport POV of the camera is slightly in front of the one used during renders. just move the camera slightly closer to the scene.
