Issues with makeup load
This might be a little particualr and hard to explain...
With the MeiLin character there are 2 variations of makeup applications. MakeupA = shows eyebrows, MakeupB = shows no eyebrows.
When I load any of the MakeupA, it loads fine. When i load MakeupB, the face becomes lighter.
This is happening with a character I have loaded, but does not happen if i start a fresh model and try to re-create the character and the problem.
I don't know what I am doing wrong and what is happening differently between the 2. I have checked and compared all the Surface settings for the face and they all seem to be identical.
If anyone could put me out of my misery, I will be forever greatful.
  • I don't see this. When did you download Mei Lin 8 from your account/install through Connect?
  • mruu88mruu88 Posts: 11
    Yes everything was installed correctly and working fine. I made some slight modifications to the makeup templates on photoshop and then it started doing this problem. I really can't understand why there is the inconsistency though. Why is there no issue when i build a new mei character but there is this issue when i modiy my loaded one?? :/
