Optix Prime error
On some rather recent products such as PW's Bikini Islands, trying to load the alternate skydome settings gets me a "Optix Prime not supported anymore" error window. I tried with and without the option ticked in my render settings. Is there a way around this?
  • Ignore it - the option no longer does anything, so if the render settings try to set it to on the log records a note that it isn't supported. The entry has n greater significance, and should go away in the next update (depending on which version you are currently running).
  • I'm on 4.12.0.86 right now. As much as I would like to ignore it though, the skydome, which is supposed to change, doesn't.
  • Richard HaseltineRichard Haseltine Posts: 111,430
    edited December 2019
    Thatb isn't going to be related to the OptiX Prime setting, though.
    Do you have the full set loaded? The Skydome mateials are Herarchical preset, so they will fail if the target is aprented to the wrong thing.
