FLUIDOS II plugin for Carrara
Merry Christmas!
FLUIDOS II is the new fluids simulation plugin for Carrara 8 and 8.5.
FLUIDOS II incorporates high-performance OpenVDB tools for meshing, filtering, level sets, and pressure projection. Besides the superior quality liquid simulation, now it includes other fluids types: Smoke and Volumetric fire.
FLUIDOS II is faster, much more powerful and versatile than its predecessor, FLUIDOS v1.4.
For Windows 64 bits and macOS 64 bits. You can download here: https://sharecg.com/v/94992/browse/9/Plug-in/FLUIDOS-II
As with its predecessor, it's for free for the Carrara community (Donations are welcome, cheeky but not required at all)
Daz Studio version is here
«134
  • JamyJamy Posts: 192
    Merci beaucoup et Joyeux Noël :-)
  • 3drendero3drendero Posts: 2,029
    Thanks for the christmas gift.
    Thank you!!
    and for the genesis morphs eraser
  • DiomedeDiomede Posts: 15,388
    Thank you again.  This is great.  You are very generous.
  • DartanbeckDartanbeck Posts: 21,937
    I don't know what Jamy said, but I like it! So, ditto that for me! heart
    Thank you So Much!!!
  • Bunyip02Bunyip02 Posts: 9,231
    Many thank-you's !!! yes
  • mindsongmindsong Posts: 1,724
    Goodness - considering the price for the DAZ version, this is truly a gift.
    I tossed a wee bit in the tip jar, and hope others will do the same.
    (and no, this doesn't mean I bought it... it's still a *wonderful* and generous gift from you to me, but perhaps you can have a good glass of wine near your keyboard as you do your magic!)
    Merci beaucoup!
    --ms
    Merci beaucoup!
    --ms
    +1 heart
    sad
    Two solutions :
    1) I'm a dummy
    2) Fluidos do not works with Mac OS Sierra
    anyone tried with this system?
    For Dartanbeck
    Merci beaucoup et joyeux Noël
    >>> thank you very much and merry christmas wink
    edited December 2019
    @Jamy Merci beaucoup!
    Post edited by Dartanbeck on
  • AlbertoAlberto Posts: 1,456
    Wendy, Jamy, 3drendero, Misty, Dart, Bunyip:
    Your welcome!smiley
    Mindsong:
    Thank you! smiley
    What are the symptoms?
    Post edited by Alberto on
    I have placed the extension folder correctly,
    In Carrara, I opened your "liquid example" file
    I chose GPU in the "advanced" tab because I noticed that it does not work with CPU
    When I launch FluidosII, I choose a new folder and the calculation software. At the end I have a button "Done!" OK, so far everything seems OK.
    But then when I start reading, nothing happens, no movement, nothing.
    I did some tests with old files and it doesn't work either.
    Then I came back with the old Fluidos 1 versions, and again I can't get anywhere.
    I think that it does not come from your software, but from Carrara which does not work very well with MAC OS Sierra.
    Please, go to the ouput folder, look inside the bakefiles folder: Do you see any file?
    Now, look inside the logs folder and open the last one log file. Could you upload it here?
    Alvin,
    in the bakefiles folder there is a lot of files (184,1 Mo)
    I upload thelog file
    txt
    txt
    27-Dec-2019 18h23m00s.txt
    181K
    Jamy said:
    Alvin,
    The results are there.
    Did you enable the viewer to see the results? Select the viewer, go to Modifiers tab and Fluidos viewer, check Enabled. Some scenes have more than one viewer, you can enable only one or all of them.
    Alberto said:
    Jamy said:
    Alvin,
    Sorry, it"s the same thing, nothing move :-(
    526 x 918 - 73K
    Post edited by Jamy on
    Jamy said:
    Alberto said:
    Jamy said:
    Alvin,
    I see the problem now! Just set the folder input box to the same folder output of the Domain.
    Alberto said:
    Jamy said:
    Alberto said:
    Jamy said:
    Alvin,
    Thank you for all that Alvin, but I don't understand what you are explaining (I think I'm a real dummy)
    Jamy said:
    Alberto said:
    Jamy said:
    Alberto said:
    Jamy said:
    Alvin,
    I think it's my English.sad
    Put here the folder where your simulation's data are (the same where you found the four subfolders: bakefiles, logs, savestates and temp at this post: https://www.daz3d.com/forums/discussion/comment/5204736/#Comment_5204736)
    Alberto said:
    Jamy said:
    Alberto said:
    Jamy said:
    Alberto said:
    Jamy said:
    Alvin,
    Hooray !!
    it's good Alvin, it works !!
    You are a genius. Thank you so much for this Christmas present and for your dedication to helping.
    I hope one day to be able to put my talent at your service too
    very good day to you
  • HeadwaxHeadwax Posts: 10,385
    thanks so much Alvin - you rock :) !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Oups !!!
    nothing is won yet Alvin :-(
    I have a crash when I activate the "viscosity" function
    Here is, as an attachment, the "log" file
    (only 3 files in bakefiles folder)
    I will test the other examples
    txt
    txt
    28-Dec-2019 08h09m26s.txt
    4K
    first tests :
    Liquid example = OK
    Liquid example+Viscosity = CRASH
    Viscosity example = CRASH
    Fire example 1 = OK
    Fire example 2 = OK
    Explosion example 1 = OK
    Explosion example 2 = OK
    I think it's the viscosity that is the problem.
    I also had a crash with an old file where there was a viscous liquid (a honey test)
    My system :
    MacOS Sierra
    10.12.6
    Processor : 3,5 GHz 6-Corel Intel Xeon E5
    Memory : 32 Go 1866 MHz DDR3
    AMD FirePro D700 6144 Mo
    If it helps, I'm ready to do other tests
  • DUDUDUDU Posts: 1,945
    @ Alvin:
    I tested Fluidos2:
    The main point for me is multi-threading, fine!
    I’m sorry, but I forgot a few things.
    1- How do I see the particles (foam)?
    2- What are the "Physic" and "Moving solids" options used for? An object in collision with the fluid remains immobile.
    3- Is it possible to create a domain to "kill" the particles that pass through it, and not simulate a collision?
    4- In RF, there is an option "Make initial state", is there one in Fluidos? ("Initial state" places the end of the previous simulation to the first image.)
    In any case, thank you for this new version!
    Jamy said:
    first tests :
    Liquid example = OK
    Fire example 1 = OK
    Fire example 2 = OK
    My system :
    MacOS Sierra
    10.12.6
    You're right. Thank you!
    I found the bug and fixed it.
    Please, extract the contents in this zip and replace the old "libfluidsimII.dylib" in "Extensions/FluidosII" folder with the one in the zip.
    Try again and let me know.
    https://drive.google.com/open?id=1jPHhIkFZCkHA-wZI94Cq_Edn5qpL3NNM
    DUDU said:
    @ Alvin:
    I tested Fluidos2:
    1. Create a new viewer (any object with the Fluids viewer modifier, this one is the same FluidS old modifier). Select "Diffuse particles" in type of mesh.
    2. The option "Moving solids" is to get the fluids reacts to the solid movement. It doesn't move the solid, it's the fluid that is pushed by the solid. On the other hand, "Physics" option allows the liquid to push the solid, by using the Carrara's Physics solver (however, it's an slow processing).
    3. In principle, yes, using sinks alongside the walls, but some fast particles could collide anyway; to avoid this behavior, you should use a higher FPS in the domain or a lower CLF condition number (Advanced parameters in Domain).
    4. Yes. In Domain, click in Preset file, and select the "autosave.state" file in the autosaves subfolder of output folder (Before, change the name of the autosave if you want to preserve it). Then when starting the simulation, choose the Preset instead of New simulation.
    You're welcome.
    You're welcome!
    Yup, I have to get back to reading. I've been without a computer for too long. The presets don't just load and render, I presume. If they're supposed to, perhaps I don't have everything installed correctly.
    Gonna read the manual either way ASAP
