Error during rendering
My render (in 3Dlight) was "stuck". Started, but didn't progress at all after the first few "lines". I tried several times to no avail. I restarted DAZ Studio and tried again. This time, the render didn't even start and I got an "error during rendering" message.
The last lines of the log are the following :
2019-12-16 08:10:27.289 WARNING: QColor::setHsv: HSV parameters out of range
2019-12-16 08:10:27.290 WARNING: QColor::setHsv: HSV parameters out of range
2019-12-16 08:10:27.382 WARNING: QColor::setHsv: HSV parameters out of range
Earlier in the log, I find this :
stdin:447: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
stdin:460: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
What could could cause this problem?
is it failing even if you just create a sphere primitive in the middle of an empty scene?
Not at all. It failed only with a specific scene, based on a previous one that had rendered normally.. I deleted the scene and redid it on the same basis, identically I think, except for a set of hair that I suspected to be maybe the guilty party because when the render was "stuck" it was always when the rendered "lines" reached these hair (but when I got the "error during rendering" message, I got it with or without the hair, so I don't know). The new version of the scene rendered normally.
