Problems with Ping...
lss_pblss_pb Posts: 17
Post edited by Chohole on
  • thd777thd777 Posts: 946
    It seems that you have not downloaded the dForce starter essentials which contain the dual lobe shader. You can find them on the DAZ studio page of your download library or in DIM.
    TD
  • lss_pblss_pb Posts: 17
    edited December 2019
    ok I got it to stop giving me THAT error, now I have another issue :( I get one of 2 kinda of renders, a very muted version of the texture... or this...
    example of the muted render I get
    It looks like you are using the 3Delight render engine, but the figure is set up for Iray? Try switching to Iray. Also I do not see the fur, did you remove it or does it not show up?
    TD
    doesnt show up
    I very rarely use daz studio, I'm not entirely comfortable with the program, so please dont think me stupid, but how do i change to the lray?
    Post edited by lss_pb on
     Nothing to do with stupid. No worries. Hmm, which version of DAZ Studio is that? I have the feeling that you might not have updated in a while? Check "About DAZ Studio" in the Help menu for the version number. Also what kind of computer are you running? Is it a PC or Mac? If PC what version of Windows? Iray is only available on 64 bit systems if I recall correctly.
    TD
    Post edited by thd777 on
    TD
    4.5 pro I think, and I have win 10 64 bit
  • mclaughmclaugh Posts: 221
    DAZ didn't natively support iRay until 4.8.
    Well, neither the fur nor Iray are going to work in 4.5. Those features got added later at about 4.10 and 4.12. You will need to upgrade to a newer version to use the figure as intended.
    if you decide to upgrade, I would either make sure that you still have the installer for your current version so that you can go back if there are System incompatibilities. Or you could install the current beta version of DS 4.12 which you can install in parallel with your current version via DIM. It's called the "public built" and if you never had one before, you need to first "purchase" it in the store (it's free).
    ciao
    TD
    thanks for the help, I'm a poser girl, always have been. I"m more comfortable with it lol I'm just in love with LLF's new plushies lol I had to have one
    No worries. We all use whatever software we prefer and are comfortable with. Remember, if the figure doesn't work for you, you can return it within 30 days thanks to DAZ's easy return policy.
    ciao
    TD
    Thanks to your help I think I managed to get it to work :)
    thanks again thd777
    Yay! Looking good. Cute critter. Good to hear that you got it working.
    Have fun!
    TD
  • john_antkowiakjohn_antkowiak Posts: 338
    oops.... nvm. I spent a long time trying to figure out this advice, which should apply to my variation on the OP. Couldn't do it. So I spent a long time preparing a detailed question, with screenshots and all... and THEN I figured it out. Of course, I can't just delete my reply - so I'm changing it to say:
    False Alarm. Thank you anyway  :)
    Post edited by john_antkowiak on
    @john_antkowiak go to your product library in your account and type "starter" in the filter box. One of the things that show up when you clivck filter should be "dForce Starter Essentials". That's the one you need. See the attached screenshot from my library.
    The dual lobe shader is just a shader optimized for dForce and strand based hair.
    Ciao
    TD
    1920 x 1725 - 676K
