XTransfer Module 1- Genesis 3 to Genesis 8 Morph Converter (Commercial)
1…1213151718…38
  • RhaleRhale Posts: 78
    This is crashing Studio on every use: crashes both Daz Studio 4.12.0.86 Public and Beta 4.12.1.16 (MacOS 10.15.1). A partial morph is saved but is distorted (similar to the report by Gordig on page 11).
  • Zev0Zev0 Posts: 7,123
    edited December 2019
    OK the crashing is causing the distortion, we are working on why it crashes. Can I get a copy of your logfile so we can compare against others? Thanks
    Post edited by Zev0 on
    Cheers for the update, best of luck!
  • TheNathanParableTheNathanParable Posts: 1,089
    I. Am. Loving. This.
    XT Kenji 7 with Yuzuru 8's textures, and XT Guy 7 with 3DU's Pace textures.
    615 x 751 - 64K
    466 x 704 - 54K
    625 x 647 - 53K
    Post edited by TheNathanParable on
    Oh wow those came out great Nat.yes
    Oh, and I figured I would try some more e-x-t-r-e-m-e shapes, to really put XTransfer through its paces.
    Here we have both 3DU's Pixie and Marcius' TeeRex, both converted to G8M (and using the default G8M textures and G8M basic wear shorts).
    503 x 789 - 39K
    621 x 786 - 42K
  • Zev0 said:
    To get Jade across all you have to do is favourite this morph.
    Gave that a try and DS crashes at 71%. Last message in the history is:
    Loaded file: PHMEyelashesCurl.dsf
    At that point, did you force quit it, did studio crash as in close completely, or did you leave it alone..It should get past that point eventually. It actually isn't crashing, its rigging all morphs at that point but it also locks up the status. If it did crash as in close studio then that is another issue, and something we are looking at. We also trying to implement a way so we can see exactly what the script is doing behind the scene.
  • mclaughmclaugh Posts: 221
    Sorry to report that Xtransfer crashed at 71% and seriously screwed up something in my DS install: attempting to load any G8F figure or any scene containing a G8F figure crashed DS. Deleting the XTransfer folder (recommended upthread) and rebooting appears to have fixed that, so I can load G8F figures again, but there's still a (live) Genesis3 Female Genesis 8 property (which produces a seriously broken character) in the Parameters/Actor/People pane for all my G8F figures. I know I can delete the property from every G8F individually, but is there any way to get rid of it globally?
    Thanks.
    Can I see a screenshot of your genesis 8, and also what is being used morph wise via the currently used option? Deleting the Xtransfer folder removes it completely off your G8, so if something is left behind as you describe I need to see.
    Crashes withn a couple minutes. I was able to see the history dialog while the crash dialog was up. Crashed at 2m 10s.
    I tried changing to Main Street and Full Service and it crashed at 1m 49s on XT_FHM-FWSAJade.dsfI;m not seeing any G3F  XT_ files being created (or at least System.FileName:~XT_* is not finding them). Note: second attempt was from a saved scene that I deleted cameres, outfits, hair, etc. from anf the first attempt today was after a fresg DS start loading Jade from Smart Content.
    You only supposed to convert from a new scene with a default G3. Do not use a pre-existing scene. If it happens in that new scene again please send your log file.
  • Oso3DOso3D Posts: 15,125
    Genesis Ribbits ( https://www.daz3d.com/ribbits-for-genesis ) -> G3F -> G3M (for some reason it was erroring going Genesis -> G3M so whatever) using GenX2
    Then XTransfer G3M -> G8M.
    I don't have the special stuff to transfer pre G3 textures, so I rummaged through and landed on Giant HD Blue ( https://www.daz3d.com/giant-hd-for-the-brute-8 )
    Not 100% happy with the lighting, but... woo!
    If I were going to tinker more, I'd probably come up with my own JCMs; the belly and neck, predictably, fold badly in some poses.
    1000 x 1300 - 396K
    Reptilian 6 -> G3M with GenX, then Xtransfer to take it all the way to G8M.
    I used the Alien-X skin, since it's suitably reptilianish, and I think it came out rather well!
    (The feet are blank, because I think Alien-x uses geograft feet, so... not showing the feet)
    1000 x 1300 - 327K
    Post edited by Oso3D on
    That one came out great!
  • Yeah, it's crashing from a new scene as well.
    Logs messaged to you.
    Thanks I got them.
  • JerifeJerife Posts: 272
    Subtle morphs transfer very nicely:
    Here a G8F with OOTs bikini and micromorphs
    You can see it applied in the right figure
    1424 x 712 - 469K
    Post edited by Jerife on
    Jerife I sent you a PM.
    Can't show here but wonderfuly transfered. Thank you very much
    Zev0, I replied to your PM and included a screenshot and a compressed file. I may have found a culprit (G3F character) for my problems, but I'll leave you to see if I'm correct or not.
    You are a genius and your script awesome!
    Here Mabel8 on a G3F garment, Pletaix by Powerage, with and without the Pose Control morph. I injected the morph that comes with the pantie over the G3F base and XTransfered laugh
    3200 x 1600 - 3M
    PM sent.
  • I installed XTransfer yesterday and after doing one morph, DAZ studio (both 4.12 and it's beta) would suddenly close (crash) while loading any G8M figure. Today I went ahead and renamed the folder where morph was at, along with another product "Character Converter from G3M to G8M" since that was also causing the figures to take a long time to load. I then uninstalled and installed both of the Daz Studios, and now after two minutes or so, the G8M figure loads but it is deformed (see attached). Is there a way to fix this? I already submitted a ticket yesterday, but now being able to load it all deformed is new.
    Thank you in advanced.
    765 x 715 - 372K
    Hi I sent you a PM. Also, Delete the XTransfer folder in Genesis 8 data if there are distortions. That will reset the figure.
  • Awesome, thank you, Zev0 for the prompt response. I replied back to your PM, which solved the issue. Thanks again for all your hard work.
  • GordigGordig Posts: 10,816
    Got the banner for free Glute Control, so thank you, even though the link isn't working yet.
  • Robert FreiseRobert Freise Posts: 4,703
    I just put it in my cart and it worked
    Thanks for the gift Zev0
    Post edited by Robert Freise on
    I was just able to 'purchse' the free Glute Control from my purple banner just now, so maybe it'll work for you now too!
    Thanks for the gift Zev0, and for the continued support of this product. I'm looking forward to future XTransfer modules.
    Cheers,
    Daniel
    Thanks for the male glute control, Zev0!
