UV Maps
I used XTransfer and after many tries, Mr. Bear transferred smoothly to G8M.  The product has it's own UV map layout, so when copying the surface materials to G8M, they do not line-up.  Is there a way to correct this issue?  Thanks.
    If it has it's own UVmap then you will have to transfer the one UVmap to GM8 and change it's UVMap, not an easy process from what I hear.
