Are Springs possible in DAZ?
I was woundering if anybody has any luck importing a charcter attachment or any other object that has had a spring effect applied to it from an external program like Iclone, Blender or Carrara? I have been able to export a G2 Character into Iclone before and apply a spring there but I was not sure how to import the effect into DS. Anybody know how to simulate springs in DS, like a tail, or bunny ears or any type of geograph attachment? (I'm really wanting to apply springs to a feather prop I was looking at buying.
  • kwanniekwannie Posts: 870
    Maybe: Would spring effects be possible with DForce?
  • CybersoxCybersox Posts: 10,038
    edited November 2019
    There's a bunch of morphing spring props included in Maclean's Morphing Primitives set https://www.daz3d.com/everyday-morphing-primitives  Just pop 'em into your scene, with a shader of your choice and dial in the shape and pose that you want.  .
    Post edited by Chohole on
    @Cybersox      fixed your link,  it was throwing a 404
  • Pity its not what the OP meant cheeky
    I discovered how to do them in UE4 last week
    the spring bone movement does export from 3Dxchange in a BVH but you need to manually check the bones under advanced on the DAZ studio import dialogue.
    What do you mean manually OnyLuvsCatz? You mean verify something or do you mean there is a selection box that needs to be checked?
    Bvh import you get a dialoge with advanced, you open that and tick all the bones on the source and target figure bone hierarchies such as pectorals for boob bounce etc.
  • Make sure tou export your bvh with hip not node0 etc selected as base in 3Dx
    can select hip or thr base figure in DAZ for import and I usually get the rotation axis wrong first go so no good asking me thatcheeky
    make sure its the same figure
    Ahh.......Ok. So will it export the bvh for everything even if the springs were applied to a geograph attachment like a tail?
    Yes but you need to load it again on the tail in DAZ studio
    If I follow correctly, you mean select the tail in the scene hierarchy window then import the bvh with the only the tail selected?
    Yes
    Thank you so much! OnlyLuvsCatz
