Problem with renders
Hello, I'm new using Daz3D and I have a problem that I can't find a solution. When I use a texture with pattenrs, they get like pixelized, I don't know how to explain that... I leave you here an image of the problem. Hope someone can help me with this because it happens also when I use a texture that has stitches on it... https://gyazo.com/4977d531d5524610723e25e26c23ef0a
  • Work with .png or .tiff formats.
  • AJ2112AJ2112 Posts: 1,416
    edited November 2019
    From what I can see, reason for pixelation is due to image size resolution.  Texture image should be large, I use 2000x2000 min.  Image your trying to use is 456/408
    Post edited by AJ2112 on
