Pausing Renders
Ive tried to save my render after pausing it with a view to continue later but its not worked.
Is there a way to save a render so I can continue later?
thanks.
  • barbultbarbult Posts: 27,153
    With Iray, cancel the render. Then in the File menu select Save Last Render. Then Resume your Iray render from the Resume button in the image render window.
  • mclaughmclaugh Posts: 221
    @barbult - I read the OP's question as wanting to save the current state of the render, not just a partial render and resume it immediately. (Think Photoshop, where you can fiddle with an image, save your changes, close PS, and open it at a later time/date and resume where you left off.)
    @glennblackphotos - assuming I understood your query correctly, AFAIK, that's not possible in DS.
