PowerPose
Just discovered, due to lack of use, that I only have 6 points of movement for the head in PowerPose, whereas on YouTube I see there are many more available. How do I update or install these extra points?
I'm using Daz Studio 4.12
Which figure are you using?
The extra points only exist for Genesis 8 Female and Male, not earlier figures. It sounds like you have not installed the PowerPose Templates files - if you use DIM they are under SKU 42071 file id's 4 and 5. I've attached where to look in your Product Library here at the website if you install manually. Go here: https://www.daz3d.com/downloader/customer/files#prod_42071
