Problems with FLUIDOS
Hi,
I have just purchased FLUIDOS for Daz3D and installed it via DIM.
In the Users' Manual, in order to start working with this plugin, they say to go under "Create" and select "New Fluidos Domani". But there's not such option there.
Then, if I go to "Help" > "About Installed Plugins", it says that the plugin is inactive because it needs registration... but where can I find the registration code?
Thanks!
If you right-click the Fluidos plug-in in the Installed tab in DIM you shoudl be able to copy the erial number to the clipboard; you can usually also find your serial numbers in your account pages https://www.daz3d.com/downloader/customer/serialnumbers
