My turn for system building.
245678
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    Just noting that the 3950X 16 cores should be arriving next month, as well as the new Threadrippers.
    You had 3900X in your specs, hence my mention. Really, the main advantage of more cores is for those times when renders drop to CPU only, IF Daz Studio can take advantage of larger core counts.  Otherwise, if you avoid CPU only renders like the plague, really the 3700X should be plenty fine unless you have need of more cores for other things, like video editing.
    Personally, I'm planning on an Asrock X570 Creator motherboard.  It's pricey, but has Thunderbolt 3 support.  Thunderbolt 3 options aren't all that common in AMD land.  I'm wanting the Thunderbolt support for other things that aren't Daz related.  I have a Threadripper build planned as well, but may hold off on that one and focus on the AM4 biuld for now.  Nvidia graphics card prices are still rather insane, so that multi GPU Threadripper build isn't as much of a priority at the moment.  I need lots of VRAM for my scenes, but spending $2500 plus for a RTX Titan is just a bit too painful...
    Anyways, back to your build, looks pretty good, and it looks like others have a lot of good suggestions.
  • I'll check out both PC Specialist and QuietPC, see how their systems compare (though I'm assuming ti will be simpler to build myself rather than try to make sure they leave the cables in place for the extra HDs).
    Is the PSU looking sensible, or does it need a bump up?
    Specing out your system really fast got me to around 600W draw as built. Adding a couple of drives would push that up by roughly 15W per drive. So unless you add 4 or more you'd still be under 650W. 65% load on a PSU isn't peak efficiency but its pretty good. With an 80+ Gold you'd do fine. If you do add something like a second 2080ti with a bunch of HDD's that would be pushing things so if you want to thoroughly future proof you should go up to 1100 or 1200.
    Thanks, I probably will bump it up to the next rating then.
    maclean said:
    I went with the Fractal Design Define R6, which is not only beautiful, but definitely the most customisable I've ever had. I converted it to open plan for a longer card, and it'll take 2 cards, no problem..
    I've also abandoned HDDs altogether. I was using 10,000rpm Velociraptors and have now switched to a Samsung M.2  + 4 Samsung SSDs. Never going back to HDDs. Btw, depending on where the M.2 goes in your mobo, it may get hotter than normal. Mine goes under the heatsink on an Asus board, but the Gigabyte may be different.
    Other than that, I can't add anything. I've stuck happily with Intel/Asus for the last 20+ years, so we're on different paths there, and I don't know enough to comment on the other hardware. The only thing I can say is I spent weeks researching every single piece, andit was definitely worth the trouble. YouTube is a great resource for hardware checks.
    Last tiem I was building it was quite easy to find lots of side-by-side reviews for things like motherboards, this time a lot of sites justs eemed to pick oen or two "best" and say nothing about the rest or how they picked. Quite a few "reviews" were clearly previews at best, reading the spec sheet at worst since they mentioned things that weren't locked down yet or would be clear only nearer release, which doesn't inspire confidence.
    Gamers Nexus does a lot of case reviews with lots of side by side data. Motherboards don't get a lot of reviews, there are an awful lot and the differences are pretty much features. However Gmers Nexus also does some motherboard reviews, they tend to focus on the quality of the power delivery systems and the board cooling. Level 1 Techs do some reviews as well and they are very production usability focused.
    Thanks, I'll check them out tomorrow.
    For X570 motherboards any of them should handle the 3900x if its not overclocked. The mid tier ones, like the one you chose, have lots of I/O and fan connectors (the biggest things I look for in picking a MoBo).
    On HDD's, If you have a reasonably small asset library and other data to store then SSD's are fine. I've got something like 6 Gb of assets plus another 4 Gb of music plus other data. That would be very expensive on SSD's.
    1GB is fine for docs, although I have had a decentish camera for a couple of years now and the (other kind of) CR2 files are mounting up at 24MB a pop. But content, I have over 1GB in DIM zips (and that excludes the Genesis 8 stuff) so SSD isn't really an option (yet).
  • GreymomGreymom Posts: 1,139
    Another possiblility when considering drive cost vs. speed for asset storage is the Seagate Firecuda.   It is a 1- or 2- TB mechanical HDD plus a small SSD that basically acts as a big buffer.  The speed and cost is between that of a sata SSD and a HDD.  The 2 TB drives go on sale periodically for about $85.  I have several, and have been been happy with them so far,  just wish they made one larger than 2TB.
    Thanks, 2TB might be workable for just DS content (I usaully also dumpt stuff like video tutroials on my "content" drive), worth a look.
  • rrwardrrward Posts: 556
    If you go with a hybrid drive make absolutely sure you put your computer on a UPS. My employer has had to get a large number of hybrid drives replaced when the SSD cache drive and the platter main drive got knocked out of sync by a power failure, resulting a loss in the drive.
    I see. Fortunately I do have a UPS, assuming it can cope (it runs the current system for a good twenty minutes if it's idling, I think it was slightly overspecified).
    All you really need is enough power to do a controlled shutdown. It's the abrupt shutdown that's hosed our systems. Temper that with my employer has several thousand computers and most of them are just fine. And you can't ever have a UPS that too high capacity. :)
    A power failure may have killed some drives by the heads crashing. You could lose some data if the caching was somehow setup for writes, it should be a read cache only. But losing drives due to some "out of sync" issue between the two? That just not how drives work.
  • LeatherGryphonLeatherGryphon Posts: 12,082
    edited November 2019
    Similarly, Crucial has a software product they call, I think, "Storage Executive" that among other things provides a RAM buffer of writes to your spiffy new SSD to minimize excessive small writes to the SSD and provide much quicker service in some situations.  They grab about 500MB to 1GB+ of RAM for their buffer and HIGHLY recommend that you run your system on an UPS power safe systemfrown.  After getting my first SSD I thought about using their buffer app, but it gave me a little bit of grief trying to install it, but  that gave me time to finally come to the conclusion that I'd live without it.enlightened  I don't want to think about losing a GB of diskwrites to my SSD.crying
  • Hurdy3DHurdy3D Posts: 1,073
    As an alternative, shadow.tech (cloud computing) is soon upgrading their systems to RTX.
    https://www.reddit.com/r/ShadowPC/comments/dorchd/recap_shadow_keynote_october_29_2019/
    For me 2TB max storage is not enough, but the rest of the max specs are nice (RTX GPU, 32GB Ram).
    It's proably a Quardo GPU, after they are not allowed to use in server farms the normal gForce GPUs... so it's very likly more than 11GB VRAM.
  • With so many good laptops these days that have NO DVD/CD internals, they have been making some pretty decent external DVD/CD readers and/or writers. I go with external harddrives for backup - even with all the best of care, etc. those little flashdrives tend to be very unreliable dying hard and fast for no particular reason. One has lasted YEARS but others start popping up those 'need to be reformatted' warnings and they were no where near the filled line. [and the soft textured types of any drives MELT [go all sticky gooey] in the summer heat]
  • StratDragonStratDragon Posts: 3,273
    the 1660ti is a great card, low power, runs silent. The research I did before I bought it showed performance vs price it was one of the best all around cards.
    ... One has lasted YEARS but others start popping up those 'need to be reformatted' warnings and they were no where near the filled line. [and the soft textured types of any drives MELT [go all sticky gooey] in the summer heat]
    Off topic, but yes, whatever that plastic concoction is that gives a nice velvety feel to plastic devices for the first 6 months of its life, does not stand the test of timeangry.  I have a pair of really nice binoculars that degraded into sticky hellsad.  I tried cleaning it with alcohol and a great amount of hard rubbing which had a small measure of success but the gooey sticky feel would comeback shortlyfrown.  The problem is not a coating on the surface of the plastic, it's the plastic itself degradingindecision.  I finally solved it by coating the outside with talcum powdersurprise.  I figured if it wanted to stick to something then, HERE, stick to this!devil  Haven't had a problem sinceyes.  But once in a while I touch up the powder coating as it wears offenlightened.
  • WinterMoonWinterMoon Posts: 2,014
    Vinyl plastics are known to disintegrate and become sticky with time. The chemicals in it react with so many things it can hardly avoid being exposed to. Ever wondered why dolls are usually the dirtiest toys in the box? wink
    Yes, I ddi see that there were stand-alone units - and not having the internal bays would probably improve aitflow. Haven't yet had tiem for a good look at other cases, though, and I still want to avoid upward-facing ports.
  • Having done some brooding I'm fairly happy with where I am - which is pretty much the original build with a bigger PSU, more RAM, and a 1650 Super instead of the 1650 Ti as the display GPU. Just a few dot-the-Ts-cross-the-Is to finish, if I may:
    Does Windows 10 need additional software for Bluray burning? It looks like yes, in which case the stand-alone drives (which come with software) may work out cheaper than the internals (which don't). On the other hand, from past experience, the big burnng suites tend to do a lot of stuff and try to spread their tentacles everywhere, and of course an external is an extra bit of clutter.
    Does anyone have experience with the case? It appears to have a mesh top - good for ventillation, possibly less good when the cat sees a nice flat area on top of a warm, humming thing. Most of the other cases have the upward-facing ports, or are really weird shapes, or both.
    The stock cooler doesn't need additional thermal paste by the look of it - is that correct? I'm pretty sure ken Shaw, at least, has said theya re fine for our uses (since I have no plans to overclock).
    The motherboard has plenty of USB ports, except that there are no PS/2 ports so the mouse and keyboard will need to use two of them (plus five others that are currently in use in this system) - that will just leave a couple of the USB 3 ports free - and once the budget recovers I could do with new speakers. I suppose the obvious answer is a hub (or perhaps plug the camera cable into the monitor's ports), the other motherboards in this price bracket seem to have fewer ports rather than more.
  • nonesuch00nonesuch00 Posts: 18,714
    How much clout do you have nagging the DAZ product managers? You can say you want Radeon Pro Renderer plugin to be integrated into DAZ Studio and buy a Ryzen 5 3400G with Radeon RX Vega 11 graphics [$150 so...£100?) and bid your time till summer when the super-unbeliebably good new nVidia cards come out even cheaper than the 20xx series that you need only one. You run your monitor on the Vega GPU and renders on the nVidia GPU. Course then your 3400G CPU might seem lacking compared to the CPU you original listed as the 3400G is the best Ryzen APU available is it's only 2nd Gen Ryzen.
    I'm going to cough up $250 and get me AM4 Socket X570 MB beginnings of my new system soon as I see if it winds up on some sort of Black Friday special (or not - I'm still buying it). Exciting. laugh
  • How much clout do you have nagging the DAZ product managers? You can say you want Radeon Pro Renderer plugin to be integrated into DAZ Studio and buy a Ryzen 5 3400G with Radeon RX Vega 11 graphics [$150 so...£100?) and bid your time till summer when the super-unbeliebably good new nVidia cards come out even cheaper than the 20xx series that you need only one. You run your monitor on the Vega GPU and renders on the nVidia GPU. Course then your 3400G CPU might seem lacking compared to the CPU you original listed as the 3400G is the best Ryzen APU available is it's only 2nd Gen Ryzen.
    Well, if I nagged them I'd probably get clouted - not sure if that would help. Even if they did decide to add ProRender, in response to a clear and reasonably-argued set of requests from a range of users, my life wouldn't be worth a plugged nickel if the PAs suspected I was linked to their having another render engine to support.
    Oh well. can't have that. I don't think the DS users need make an argument to support Pro Renderer, Intel & AMD especially have made a pretty good argument to do so, they just need to write in in what's it called? openCL and it'll be supported and likely expand hardware GPU support to Intel HD Graphics in the next couple of years to boot. They could drop openGL Intermediate to offset the added support labor..
  • I have no experience with that case but it looks pretty decent.
    Yes, you need additional software to burn a bluray.
    The AMD stock coolers have pre applied thermal past, most cooolers do. I'm just not sure the 3900X comes with one.
    On the subject of too few USB ports. You might want to check into getting either a keybord or monitor with additional ports. I plug my mous into my kb. A friedn runs speakers of the ports in his monitor.
  • Oh well. can't have that. I don't think the DS users need make an argument to support Pro Renderer, Intel & AMD especially have made a pretty good argument to do so, they just need to write in in what's it called? openCL and it'll be supported and likely expand hardware GPU support to Intel HD Graphics in the next couple of years to boot. They could drop openGL Intermediate to offset the added support labor..
    The issue is that shaders for iRay and 3Delight don't work in ProRenderer and vice versa. Just as basically no PA's support either Octane or Lux Render it is unlikely any would be rushing to support Pro Renderer unless the adoption rate made the expense and time worthwhile. Since Nvidia owns something like 90% of the GPU market...
    This sounds crazy to me but this is life ... you need one software to burn the Blu-Ray AND additional software to read Blu-Ray, same company of course will sell both. The DVD/Blu-ray burner I bought came with the lite version for burning Blu-ray. To actually make movies though I use another software altogether [Pinnacle], the additional plugin for making Blu-ray was less than $10. {but one has to have a proper Blu-ray burner drive of course, not just the plugin}
    Post edited by Catherine3678ab on
  • Richard HaseltineRichard Haseltine Posts: 107,945
    Thank you.
    The 3900X iss descrbed as coming with a cooler, but I will double-check.
    I thought it was the case that extra software was needed - fortunately I'm not planning to do any movie making, just data discs.
    Yes, my monitor does have ports so that would probably work for speakers. I thought keyboards often had USB ports for the mouse but the ones I looked at didn't - obviously need to look harder..
  • RayDAntRayDAnt Posts: 1,154
    Seems like an overall solid build to me. Speaking as a fellow "only every ten years or so" pc updater relatively fresh from a new system build, custom watercooling (plus a case worthy of keeping around for 10+ years like my personal choice - the Tower 900) is absolutely something to seriously consider. Assuming budget/living space allows for it, of course. Clearly it's a whole additional can of worms to get into. But there's something to be said for a comprehensive cooling system that can be so loosely coupled to specific system hardware as a WC loop when your talking about a computing system expected to last 10+ years.
  • I'm a little wary of water-cooling, and have seen mixed reviews, so at least initially I think I will go with air and see how that does. That's a very different looking case, it needs some fancy edging and it could be steam-punk.
  • kenshaw011267kenshaw011267 Posts: 3,805
    custom water cooling isn't worth the effort except for hobbyists and people who want to overclock heavily.
    The chances of the loop leaking when built is not zero and increases when an inexperienced person does the fitting. That means a rather tedious process of packing the rig with something absorbent that will show drips, finding the loose fitting tightening it, letting the entire system dry out then going through the whole thing again.
    Maintenance is also a PITA. draining the loop has to be done every 6 months of so (Even distilled water and a biocide will pick up enough stuff off the inside of the tubing to allow bacteria to grow). You'll need to drain the loop, flush the system and then refill which is at least a couple of hours even if you built the loop to facilitate it and know what you're doing.
    Doing a full loop including the GPU involves disassembly of the card and installing the water block. This is another tedious procedure that has to be redone regularly as the thermal paste degrades and has to be redone.
    For keyboards with USB hubs, it tends to be a feature on the higher end kb's. You might be better off, unless you're a mechanical kb snop like me, to buy a usb hub and just plug your kb and mouse into it. Probably be cheaper tbh.
    Post edited by kenshaw011267 on
  • ArtAngelArtAngel Posts: 1,942
    My current PC will be ten in the spring, and I've been dithering over updating for years (which does at least mean there's a substantial budget, though I wouldn't want to max it out). The impending round anniversary has finally prodded me into soem form of action.
    So far, my provisional specs are:
    • Motherboard    Gigabyte AMD Ryzen X570 AORUS PRO AM4 PCIe 4.0 ATX Motherboard
    • CPU    AMD Ryzen 9 3900X Gen3 12 Core AM4 CPU/Processor with Wraith Prism RGB Cooler
    • RAM    Corsair 32GB DDR4 Vengeance LPX 2666MHz Memory Kit
    • GPU 1 EVGA NVIDIA GeForce RTX 2080 Ti 11GB XC GAMING Turing Graphics Card
    • GPU 2 EVGA NVIDIA GeForce GTX 1660 Ti 6GB XC Black GAMING Turing Graphics Card
    • SSD    Samsung 970 EVO PLUS 500GB M.2 PCIe High Performance NVMe SSD/Solid State Drive
    • HD      Seagate 4TB BarraCuda 3.5" SATA HDD/Hard Disk Drive ST4000DM004
    • PSU    Corsair 1000 Watt RMx Fully Modular RM1000X ATX PSU/Power Supply
    • Case   Corsair Obsidian 750D Airflow Edition Full Tower PC Case
    to which would be added my data and content HDs from the current system.
    I was thinking of two GPUs as, with my current system, an Iray render brings everything else to a crawl - it's really hard to type a forum post due to the lag on characters appearing (sadly, that isn't the reason for most of my typos). Another option would be to go for a 2070 or 2080, which woudl still be leaps and bounds ahead of the 750Ti in this system, and see what the next round of GPUs bring - though presumably there'd be a wait for those, and then for Iray to support them - but I don't know what the odds on there being more memory at equivalent levels in those would be. Of course if they did bring more memory, and assuming it was a couple of years before they are out and suported in Iray, I could always switch the 2080Ti to the display card and add one of the new mdoels beside it without too much regret for the 1660.
    Cases are a big query - that was just grabbed as reasonably well reviewed, and although it has all the ports at the top (which seems to be the standard) at least they aren't upward facing to act as dust traps. Ideally I'd like the system to be as quiet as possible at idle, and no louder than necessary when busy. That is very open to alternative suggestions. (It would be nice to be able to add an internal DVD or BlueRay burner, too, for backups.)
    I'm not sure if that's the ideal RAM, though PC Part Picker OKs it (and the rest of the bits) - I can't recall what the current advice on optimal speeds is, and the MB manual is not long on suggesting what attributes are recommended (sadly Crucial didn't seem to list the MB, otherwise I'd have used their system to get specs). Not sure whether to stick at 32GB or go for a full 64GB, certainly don't see any need to go up to 128GB.
    The PSU may be a bit underspecified if allowing for the possibility of a second big GPU, and with a total of three mechanical HDs.
    I'd be grateful for advice, especially on bad or missing choices. Thank you.
    It always comes down to the basics. The one thing I learned (the hard way) was the case is of the utmost importance. Hot cards (even with a water cooling system) need room to breath. My 10K system from Falcon (who supposedly make servers for google) died within a year because the cage was too tight. Make sure the case has room for what you need and what you may need in the future.
    Zatetic said:
    Seeing the recommendation of 64 GB of RAM gave me an instant flashback to my Commodore 64 (KBs of RAM).
    Ha ha ...  I too had one of those back in dem der days!
    Had the same opinions about water cooling and went about things pretty much the same way when I started my new build around 1.5 years ago (only exception was that I had a zero-rpm capable CPU AIO in there pretty much from the start.) What I learned during that process is that my two major design requirments:
    1. Virtually silent operation under low-medium intensity CPU/GPU workloads.
    2. Maximum cooling performance under intense CPU/GPU workloads like rendering.
    Were virtually impossible to achieve in a modern fan/heatsink machine since:
    1. Modern CPU/GPU VRMs are noisy as hell (especially the ones found in Nvidia 2080 Tis/Titan RTXs.) Meaning that ventilation friendly cases (like the one I originally went for and ended up reselling: the Core X5 - I have a thing for cases that eliminate GPU sag) will not lead to virtually silent operation under casual workloads no matter how many zero-rpm capable fans you throw at it.
    2. Sound isolation focused cases (like all the BeQuiet ones) feature poor to terrible airflow performance as an unavoidable side-effect. Meaning that maximum cooling peformance under intsense workloads is a no-go.
    So then it occurred to me: Why not have a case where all the things that unavoidably generate noise (like VRMs) go inside a (relatively) sound proof chamber, whereas noise sources (like fans) that only need to be on some of the time get exposed to open air?
    Enter the Tower 900 with its solid steel and glass (two of the most effective sound blocking materials btw) twin compartment design featuring fans/radiators in the ventilation friendly back and constant noise-generating VRMs/pumps in the relatively noise-isolated tempered glass front. Based on my recent experiences this case - and this case specifically - plus watercooling equal one of (if not The) ultimate solution if low-noise and maximum cooling performance are BOTH of the utmost priroity for whatever it is you do.
    And as for the catastrophic failure factor - take another look at a picture of this case and notice the layout. Apart from the waterblocks on motherboard components themselves, everything liquid related is either in front of or in front of/below everything else. Meaning that potential leakage is pretty much a non-issue. And also notice how the inverted motherboard layout means total elimination of GPU sag (again - a pet peeve of mine.)
    This is how it looks in its current native habitat:
    Believe it or not, this is an incredibly accessible/upgradeable/maintainable - dare I say it - practical system (no idiotic things like hard tubing/colored liquid solutions/massive overclocking to be seen here...) And the looks are entirely secondary - even the RGB you see is entirely practical (individual components get bathed in different shades of light depending on what realtime temperature/cooling performance stats indicate.) As is the slightly unusual pump placement (behind the glass for sound deflection rather than down at the bottom where there's direct ventilation.) Barring obsoletion of the ATX standard itself, I honestly can't see myself ever needing to move past this case and its dual 560mm raditaor loops for whatever my main "power" computing system is unless parking space becomes an issue (it currently lives on a 12U rolling rackmount unit.)
    If longevity, noise and performance are your priorities I honestly can't recommend a system based around this case and its dual watercooling loop topology enough. Even if it is something that you would need to accomplish piece-meal (for the first 5+ months everything you see here was just air/aio cooled.)
    1661 x 2407 - 2M
    Post edited by RayDAnt on
  • VRM's are not noisy. Defective ones may produce coil wine, which can be hella annoying, but coil wine on inductors that small is always a symptom of a poorly wound coil. The only inductor or transformer large enough to produce audible coil whine in a PC, when not defective, are the ones in the PSU and even then most of the time they don't. A properly put together system with good components is always quieter without watercooling.  A pump is always the loudest part of a computer when everything is functioning properly and the fans aren't above 50% or so. You may be sensitive to higher frequency sound, coil whine is high pitched while pumps produce lower frequency noise, but that is a matter of personal sensitivity not absolute noise.
    Just checked my rig, room ambient is 19C, CPU 40C, 1080ti is 57C and the 2070 is 54C, 18 inches from the front right corner of the case, my head position, ambient sound is 42 Dba. I'm running a render and surfing the web.
