Terradome 3 for 3delight render Iray to 3delight convert
GalaxyGalaxy Posts: 562
edited October 2019 in The Commons
Terradome 1 and 2 I own but I can't load. Terradome 3 is Iray only and thus I avoided it till today morning.
The best part is it is working fine with 3delight.
Is there anyway I can directly optimize those default materials for 3delight?
Post edited by Galaxy on
  • scorpioscorpio Posts: 8,533
    Terradome 1 and 2 are for Poser.
    The default textures are only for 3dl and will not convert to Iray. you would need to build your own 3dl shaders, or be find some 3dl shader presets that give results you are happy with.
  • GalaxyGalaxy Posts: 562
    Thanks, I will use default materials for Iray rendering. But I am happy finally this product is working for. me.
  • Oso3DOso3D Posts: 15,100
    This is a free shader I did for 3DL which allows a 'two layer' Normal based effects.
    There's no direct conversion, so you'd have to painstakingly copy over maps and tweak them... but it's something. (And free)
    https://sharecg.com/v/89313/gallery/7/Material-and-Shader/Willbear-3DL-Terrain-Shader
    Using Willbear 3DL Terrain Shader. Viewport Zone A and Zone B color is red only.
    Tree is from Jacksons field, Iray shader but rendering fine with 3delight.
    960 x 720 - 135K
    You really wouldn't want to use IRay shaders for optimum performance in 3Delight. Jackson's Field comes with 3DL material presets, so simply a matter of doubleclicking;)
    edited October 2019
    I usually select 3Delight shaders for 3Delight renders.
    This time using Metal Abounds Iray Shaders https://www.daz3d.com/metal-abounds-iray-shaders . This Iray shaders looks like working fine with 3delight though probably 3delight shaders will give better performance . This type of shaders also supports viewport texture shading.
    There is another kind of shaders those shaders are viewport unfriendly or blind shaders. What kind of shaders are they?
    960 x 720 - 41K
